LED spot lights in ...
[Closed] LED spot lights in the back of a van?
Hi Chaps,
Further to my conversion of the Transit I want to remove the internal lighting and replace it with something else. Ideally I want an easy life and non-recessed lights, just lights that can be screwed into the ply.
I have 4 power cable ends that attach to the lights with what appear to be proprietary connectors, can I just lop the ends off and connect some spade connectors to them to hook up to some 12v lights?
Cheers for your help chaps
Ricks
Posted : 19/03/2012 3:11 pm
maybe.
what are the 4 wires. in the VW there were 3. +ve, -Ve & switched -ve.
choose the right 2 and wire them up normally.
Posted : 19/03/2012 3:25 pm
ah, sorry it's just a pair on each (but four of them around the van to ttached to different internal lights) - a +ve and -ve, no switched -ve.
Posted : 19/03/2012 3:29 pm
do you need a switch then?
Posted : 19/03/2012 3:30 pm
Nope, the power is switched on or off from the cab....
Posted : 19/03/2012 3:45 pm
reckon just plug it in then. i would recommend LED lights as the power draw on the batt is much less.
Posted : 19/03/2012 3:54 pm
