led down lighters n...
[Closed] led down lighters numbers
 mrmo
The bathroom is being gutted in the new year, and the ceiling is coming down due to some water damage.
I am planning on getting some LED spots put in, question is how many is enough?
room isn't that big just under3m by just under2m, so is four enough or should i go for six? or even eight?
Basically i don't know how bright they will be to know how many will be enough, and i am guessing doing it now will be far easier than correcting it later.
Posted : 23/11/2013 6:57 pm
Ours is about the same size. We have 4 which seems about right.
Posted : 23/11/2013 7:25 pm
4 or 6. However, the answer may well be dictated by the spacing of the joists. They should be fire rated and depending on where they are positioned, ie over the shower, may need to be "IP" rated. (IP44 minimum).
If you're fitting a ceiling mounted extractor fan this will also need to be factored in to the spacing.
We specify Bell GU10 bulbs cool or warm white as you prefer. Not cheap but better than what you'd normally buy from a high street DIY store.
Posted : 23/11/2013 8:13 pm
