Led ceiling lights.
[Closed] Led ceiling lights.
Apparently they're all the rage with the kids at the moment - any suggestions for quality ones that look nice* and give good VFM?
I have absolutely no idea what I'm looking for, just don't want cheap crap.
*as far as I can think, not with big thick 'orrible surrounds.
Ta.
Posted : 26/02/2014 10:54 pm
I just installed multiple LED ceiling lights that are enclosed in metal canisters sunk into the ceiling. They are identical in size to the ones I replaced and are dimmable. Also replaced several track light spots with LED as well as all the incandescent bulbs in the house.
They were made by Utilitech, which is sold here in the US at Lowes. Not sure if that brand is available in the UK or not. but a lot of companies making them now.
Much lower wattage than the ones replaced and much brighter.
Edit: Expensive (about $325.00 for the whole house) , but they should last longer than I will.
Posted : 26/02/2014 11:00 pm
These where recommended on a recent thread
http://www.ledhut.co.uk/home-page-bestsellers/gu10-smd-led-220-lumens-45-watts-equiv-best-internet-price.html
Replaced15 halogens in our kitchen and would agree they are at least equal to the old ones
Replaced another 7 in the bathroom with the MR16 equivalent
http://www.ledhut.co.uk/spot-lights/mr16-led-bulbs/mr16-smd-led-20-pice-best-internet-price.html
I didn't need a different transformer but you might if your existing ones are not low enough wattage
http://www.ledhut.co.uk/drivers-fittings-switches/drivers-transformers/6-watt-led-transformer-driver.html
Posted : 26/02/2014 11:16 pm
We have some (from LED Hut) - you must get warm light ones for living areas. I'm very happy with ours.
Posted : 26/02/2014 11:25 pm
We just bought the £4 ones from Ikea. They seem fine to me. I've spec'ed LEDs for the new kitchen but I'm a way off buying and fitting.
Posted : 26/02/2014 11:26 pm
I have megaman - mood in my kitchen gu 10 replacements they are superb. Don't bother with cheap led's from b&q
Posted : 26/02/2014 11:34 pm
I am tempted to make the change, but need to know if I need to change the housing as well. I've got 8 lights in the bathroom on a dimmer switch. Any help appreciated.
Posted : 26/02/2014 11:37 pm
Sorry the above should be modo , dam auto correct
Posted : 26/02/2014 11:39 pm
I fit mine into existing housing with no problem. When I was looking before buying, I noted packages specified whether they can be used in enclosed fixtures or in "damp" locations and if dimmable.
Posted : 26/02/2014 11:48 pm
Wither
email or phone Ledhut, very helpful
Dimmable ones are available, normally cost a bit more, housing should be fine but you may need a new transformer (see link in my previous post)
Beic-
I had two of those Modo ones on trial, they where complete rubbish compared to the ones I replaced them with
Posted : 27/02/2014 9:20 am
I've put the LED hut ones all round my house (every bulb is a GU10!) they seem to work really well. If on a dimmer, you're going to need a trailing edge dimmer, or failing that, one that will work on a low wattage. Varilight seem to be pretty good.
All the LED bulbs have fitted into the existing lamp holders, and the only downside is that the house is a little bit cooler without them - I really do have that many that the halogens were producing enough heat to keep it warm!
Posted : 27/02/2014 9:25 am
I'm currently trying a GU10 and standard bayonet bulbs from Megaman. They're the warm white ones at 2800K and I'm very impressed with them. Quite pricey at about £10 each and I've no idea how long it would take for them to pay for themselves.
Posted : 27/02/2014 9:34 am
I have 240v ones in an en suite using standard bathroom rated housings - ours aren't on a dimmer so I didn't buy dimmer compatible lights, but if you want to use the dimmer, you must get dimmer compatible ones.
I believe that some dimmer switches don't work with LED bulbs at all though so check on that one.
Posted : 27/02/2014 10:45 am
B&Q have more or less got their LEDs sorted. The SMD zones are excellent and they also do an 880 lumen GLS which is a direct swap for a 60W incandescent. Don't knock it till you've tried it etc.
Posted : 27/02/2014 1:59 pm
We tried them recently in our kitchen ceiling and found them dimmer than halogens and they had a nasty pinkish hue so we sent them back. Will try again in a couple of years.
Posted : 27/02/2014 2:25 pm
I have JCC Fireguard lights built in to my kitchen ceiling. Not overly impressed though, as out of the 9 lights, one has stopped working already, after just 2 months. Back to Screwfix I go.
Posted : 27/02/2014 2:31 pm
i got some (4 gu10) from homebase which are a bit spotty I think 30 Deg. also got 90 or 100Deg from BQ pleased with both but the wider angle is better for us. both in warm white found that 5-7W needed to give similar output to std gu10
Posted : 27/02/2014 2:55 pm
jcc fireguards here too, throughout most of the house, some dimmable, most not.
I'm happy with them, a but more expensive then some but a good guarantee (5years, no problems with any of mine yet after a few years) and all in one units 240v with no external transformers. My brother refitted their showroom so got me a big order at a good price too which helped.
Posted : 27/02/2014 3:40 pm
Cheers all will phone ledhut to see what they suggest
Posted : 03/03/2014 6:56 pm
