Laying flags….advic...
[Closed] Laying flags….advice and tips please
I live in a 7 year old house, and the builders obviously threw the flags down in a welly throwing contest. So, I've ordered new flags and coping stones etc to spend my week off grafting in the garden (cue the snow storms 😆 )
They won't be driven over, but I want them to last, so I'm thinking few inches of crush n run, term/visqueen weed control then sharp sand??
Do I spot cement them or lay them completely flat on the sand?
any other tips gratefully received.
Have booked physio appointment in advance.
Posted : 24/04/2014 8:25 pm
Watching with interest as I have a big pile of flags in the garden waiting for me to get off the sofa and lay them...
Posted : 24/04/2014 8:27 pm
Having done this recently, I'd recommend a couple of inches of crusher run over lain by a 'dry' mix of sharp sand and cement to bed the flags on (think I went with a 1:4 mix). Get the crusher run well compacted (I used a plastic membrane underneath as this was for a workshop floor over clay) then broadly level out the sand/cement before fine tuning slab by slab with a trowel and bed the flags in with rubber mallet taps.
Posted : 24/04/2014 8:59 pm
I went for a weak sharp sand/cement mix, prevents little insects such as ants from creating huge chasms underneath that then allow the slabs to start rocking. Also stops water from washing away the sand.
1-4 is fairly strong mix...from memory I think I did 1-8ish.
Pointed it with that expensive resin based sand, very easy and quick.
Posted : 24/04/2014 9:17 pm
Edit. Mine was a damp mix, think a dry mix is normally stronger to count for lack of water.
Posted : 24/04/2014 9:18 pm
Dont bother with visqueen
Weeds that grow between your slabs are airborne weeds that grow in the sand.
Ive laid quite a number of slabs in a previous life doing landscape garden labouring and never once stuck down a membrane under slabs.
Posted : 24/04/2014 9:33 pm
Paving expert is the place for advice.
http://www.pavingexpert.com/layflag1.htm
Posted : 24/04/2014 9:46 pm
beaten to it!
see above 🙂
Posted : 24/04/2014 9:55 pm
