Community
Laptops with integr...
[Closed] Laptops with integrated batteries
 wors
Does this mean they aren't replaceable?
Posted : 31/03/2014 1:39 pm
Depends on the laptop. Some can be replaced but you need to open the case (voiding warranty usually). Others are a bit more integrated and more trouble than they are worth.
Posted : 31/03/2014 1:40 pm
 wors
OK, it's a Dell laptop if you have any knowledge of these?
Posted : 31/03/2014 1:42 pm
What do dell day? I've followed strip down and rebuild videos from their site before. Also check if they do spares for it. There is a support section that you can put the model into and it lists any factory spares they do.
Posted : 31/03/2014 2:06 pm
 Olly
A battery is a battery. They go in, they can come out. How difficult it is is another thing. Apples batteries are now surface mounted iirc, so soldered onto the motherboard. Saves quarter of a mm or some rubbish
. Obscene waste. A dell should be ok I reckon. Dell will do it for you for a cost im sure, but it might not be cheap. Otherwise hunt around online. Just need to source the right battery and bust through that warranty sticker!
Posted : 31/03/2014 2:35 pm
