Community
kindle fire trouble
[Closed] kindle fire trouble
can anyone help please . I'm trying to transfer ebooks from my calibre library to my kindle fire but each time I connect my kindle to the pc it doesn't appear on the calibre library . where am I going wrong ? cheers
Posted : 09/01/2013 7:09 pm
Mmm mine work alright , just click on Transfer to Device If I remember correctly. It was a lot easier than I thought It would be.
Posted : 09/01/2013 7:19 pm
Are you sure its even possible ?
Pretty sure the kindle fire makes using third party books as hard as possible. Think you need some kind of app file manager to do it
Try looking under Docs instead of Books.
Posted : 09/01/2013 7:24 pm
the basic kindle appears in the library but not the fire!!!
Any advice where to download ebooks from . ? ๐Ÿ˜‰
Posted : 09/01/2013 7:59 pm
are you seeing it as an external drive in my computer i had this problem and altered someting in the fire setings and then could see it
Posted : 09/01/2013 9:47 pm
it transpires kindle fire only works on Windows xp with a Windows media player 11 upgrade . done that and still cant get it sorted after 4 hours I've had enough . thanks for the tips
Posted : 09/01/2013 10:22 pm
a system upgrade to Windows Vista or similar is required . seems my old co system is outraged . crafty old amazon
Posted : 10/01/2013 5:43 pm
What OS are you running W95? - Vista is way old
You should be able to see the Kindle as an external device, providing your PC supports USB, you should then be able to simply drag and drop the files
Posted : 10/01/2013 5:50 pm
I'm running xp which doesn't recognise the kindle fire through calibre
Posted : 10/01/2013 11:58 pm
Calibre work OK with XP so it's not that
Can you not see the Kindle in My Computer when it's connected via USB?
You sometimes have to give things a couple of minutes to show up
Posted : 11/01/2013 8:57 am
have tried dragging books into kindle but can't find them on there . calibre works fine with the basic kindle on my pc but it simply isn't recognising the fire using my pc is a,bit like paddling through treacle so I've a pal who is going to upgrade me to Windows 7 probably not before time! thanks to all for advice
Posted : 11/01/2013 11:44 pm
