I have a (I think) healthy mistrust of double glazing sales people to tell me the truth, but I know that you random people on a bike forum will give me good advice.
Our double glazing is about 20 years old I think. As you can see from the photos, on a cold day I'm getting a bit of condensation in the bedroom, and it certainly feels cooler near the windows than elsewhere in the house.
They are lovely units that still seem to be in good condition, but I guess window tech has moved on?
Is there a trustworthy resource for researching windows to help me narrow down the choice and figure out how much to pay? Can someone just tell me what to get? I know that once I start getting quotes I'm going to be absolutely baffled by the options and price range.
I really don't want to shell out £1000s and have windows that look worse and perform only slightly better than the ones I already have, so reassure me that this is worth doing please and help me through the minefield!
I was talking to the guy who makes my [wooden] windows and he was saying that the tech in the glass has moved on in the last 5-10 years - by how much I don't know.
You could just replace the glazing units if you thought it would help but if they're pretty thin ones then you might need new frames also.
Are yours uPVC? Mine were replaced last year from attractive-looking wooden windows (some of which had warped and there was daylight) to dg mostly in the same style but looked worse aesthetically. Heating is only on once a day and there is no condensation which is great.
Used a local company, no hard sell and were good to deal with.
My house had double glazing from the 80s which had blown really badly and I've replaced it with quite expensive decent quality new windows in the last couple of years, and you can still feel that it's a little colder nearby than it is in the rest of the house.
I mainly changed mine for aesthetics but I was hoping for some efficiency improvement and honestly it's not really noticeable on the bills or the feel of the house.
Gut feel is that financially it will never pay for itself. I suppose if your windows were drafty that would be a different matter. Mine were just ugly and had condensation inside them from the seals failing.
Do they actually seal still? Next time it's windy, light a match and blow it out (or use an incense stick if that's your thing) and hold it near the seal to see if anything's blowing in. All the windows upstairs in our house developed gaps after 15 or so years. I think the hinges weren't lubricated, which made them stiff, and opening them put strain on the pivots. They they became slack so there was too much play, and they didn't seal.
New hinges can be fitted yourself as long as you have two people - but tie a rope around the window and your waist in case you drop it! It's quite a fiddle. You can also replace the rubber seal around the edge but there might be one on the frame and the window as well.
My daughter's room was always freezing, but I changed the hinges and now it's way better. The gap was not even credit-card thickness.
@cinnamon_girl, they're wooden and suit the house really well 😞 I'll do some investigating into replacing the glazing units @sharkbait but really no idea whether that would just be doing half a job?
We have a well-insulated house and modern double glazing but we still get some condensation like you have. In fact, I think it would take some pretty hardcore DG to not be colder than solid external walls (simply because solid walls will retain heat for much longer than glass). I assume argon-filled treble-glazing would probably just about do it, but I am sure that would be very spendy.
Bear in mind that your bedroom will be full of lots of very moist air as you use it for some 8+ hours every day.
I think, financially, you'd be better off buying a dehumidifier if you want to avoid condensation and potential for black mould.
TBF, if they didn't seal well, there would probably be no condensation (or at least less near the edges) as the ventilation would wick it away.
if the frames are sound and the double glazed panels arent blown, i'd look at getting them refurbed with new seals etc.
we replaced the windows in the older part of the house (sounds grand; just pre-extension...) last year.
They were double glazed aluminium, but 40 years old. No vents, 14mm thick etc. They streamed in the mornings at times like these, and the rooms were - despite heating, window vac, dehumidifier, ventilation etc - getting the odd patch of mould.
The new windows are aluminium, 24mm thick, with vents etc. And there is literally no condensation at all. And no mould. Is it warmer? Possibly subjective. But it feels better.
Had a few quotes; mostly around the same price. All local companies, no national chains.
Can I tell you after our bathroom window is replaced on Friday?
It, and the landing, are the last 2 to be done in the house. One frame was reglazed on the advice of the supplier/installer, but there is a clear draught coming through the bathroom window so that's getting a new frame too.
Reglazing was about £150, new UPVC frames and glass about £600 I think. We're in Dorking, so likely to be paying a bit of Surrey tax on that, but we've been happy with Dorking Windows advice, supply and aftercare.
Used another local firm at our last house and I wouldn't go near them with a shitty stick, despite good reviews.
We recently re-sealed our wooden framed windows and doors for just over £90. Fitting was easy but tedious. It has made a massive difference though, the cold draft near windows is massively reduced. Only problem now is the doors are had to lock as the seal puts too much pressure on the door.
When we moved into our house 13 years ago, one of the first jobs we wanted doing was new double glazing. It seemed to let quite a lot of noise in and we had a fair bit of condensation on the inside during the winter.
We had new glazing all round & not a lot changed, to be honest.
You can normally feel if there's a draft coming through the seals. New seals might help. New panels in the frames might help. Hard to know for sure. You could always get the glass & seals replaced in one room, assess whether it's made any difference & then either change the rest or just leave as is.
Had all my upstairs done last year, made a big improvement.
But there was an actual gap next to one of the old units, where I could see daylight.
Had all my windows replaced just before Christmas. Previous windows were 1980s aluminium and the seals had perished and a couple of units blown. Condensation upstairs in the winter was really bad, with black mould around the edges. New windows are uPVC with much thicker glazing and there's basically no condensation now and the house definitely heats up quicker, so they have made a huge difference.
We had new glazing put into identical looking windows. It has made a difference, not as much as the new windows and doors we had fitted elsewhere, but a step warmer. Our windows are not draughty.
We had 2x large (3m x 1.4m), 2x med (1.4m x 1.2m) and a smaller (1.2x1m) glazing change back in 2019 for £1k. 2 people did it all from a scaffold tower, ladders and in-room in under a day. They planed down the beads to allow for a marginally deeper glazing pane and replaced a couple of broken beads. Great value I thought. From Stirling Glass.
The new windows and doors elsewhere have made a big, big difference. I paid for better glass and coloured frames. I got them made and delivered and I fitted myself. 1x large patio doors, 2x windows (1m x 1.2m) was £2.1k or so and I spent another couple of hundred quid on cavity closers, foam, sealant and fixings. Bought from AWM in Yorkshire.
Front door: new neighbour who works as a window fitter installed on a Saturday morning for £150 with my assistance, his wife works at local door and window supplier who made it. Cost £1800 for a Solidoor and sidepanel painted to our colour all round, with upgraded lock and hardware.
We had a smarmy friendly guy from SafeStyle round a few years ago to quote for us. He brought a whole bunch of samples with him and jabbered away discussed the whole process with us in detail.
Some of their glass is coated to reflect more heat inwards or something like that for extra efficiency, he had a little gadget which touched the glass and a bulb lit up when he pressed the button. This showed it was reflecting heat.
It looked like a tiny shonky unlabelled box with a battery hooked up to an LED but I daresay it could've some fancy UV measuring tool or whatever.
Anyway, he phoned up his manager and managed to wangle us an amazing deal, 97% off the normal price! Wow!
Only available if we took the deal right that second, without thinking about it.
We went with someone else in the end... not sure why.
SafeStyle
I used to work with the owner's (then) wife. She was a PA and she came to work in one of three cars depending on her mood - a BMW M3, a Range Rover or a Ferrari. The MD asked her to stop coming in the Ferrari as he was concerned that our clients would think we were inflating our prices just so the directors could all get flash cars.
We had a load of new high performance windows installed last year. We still get a tiny amount of condensation (not enough to run) in the bedrooms when the temps plummet. The windows are covered with close fitting, thick thermal blinds. I put the condensation down to us habitaing the room for 7 hours, and a lack of airflow behind the blind. As soon as the blind is raised the condensation quickly evaporates. I’m ok with that.
AS well as new glazing units and seals around the opening parts as posited above check the frames are sealed to the building. 20 years ago it was likely that a bead (or two if a posh install) of mastic is all that is between your warm room and the outside. Nowadays the frames should be surrounded by expanding foam before the trims go on. Good news is that if the trims come off out side easily you can probably retrofit the foam yourself.
We bought new UPVC as the old frames were poorly insulated, units had blown and the installation only fitted where it touched the opening.
We replaced a couple of big bay windows, made a big difference in conjunction with heavy thermal blinds. And me crawling through the subfloor void to fit insulation between the joists...
Were you? 😉
Were you?
Well no, the PA was driving her own car (as she was the wife of the owner of SafeStyle). My MD drove a Volvo estate.
Hoping a window company turns up today to look for a similar situation in our house. One particular kitchen window you can feel the draft through and hear outside sounds when you stand washing the dishes. I'm hoping something other than a new window can be done just from a cost perspective.
I’m hoping something other than a new window can be done just from a cost perspective.
as above, seals and/or hinges are replaceable and often this solves draft and noise issues.
A company that sells windows might not be keen to offer this…
Try a window repair business or even ask some local handy people. Seals are easy DIY, hinges are moderate DIY.
The seals can be bought on eBay, there’s a bewildering array so pull a bit out and match up.
As mentioned above, 2 main aspects: the seal between the opening casement and the frame (see thin possibly rubber seal in OPs photos) effect of hinges also mentioned and the seal between the actual window frame and the house wall, often hidden by architraves/trim. Basically the seals/mastic/mortar etc dry out and shrink back and thus leave a small gap and hence you can get a draught. So not always the double glazing seal or the window, sometimes the detailing. In essence buying new windows Could help in all these areas, but some maintenance attention may also help for less money more DIY;)
Edit: also worth checking seal on the outside, possibly cement band in OPs pic, look for cracks/gaps.
We have a draughty old Victorian house that had 3 poor quality badly fitting windows upstairs with gaps in the opening. Downstairs there's a bay and another window which were both single glazed.
They were rotten, noisy, cold so we had them all replaced at huge cost and mess.
My rough estimates were that we could save around £100-150 a year. Data from the first months bills show this is about right.
If you have a modern well insulated house I'd expect that saving to be much lower.
Basically there's no realistic payback on full replacement. However, the house is far warmer, quieter and looks better all round so we're happy. I'd say it's not worth it if chasing bills alone.
I've just had my upstairs windows replaced this week. It's an old edwardian house which never heats up unless the heating is on a lot. The old windows were either single glazed, or old double glazing which had blown. In cold weather, there was condensation on all the windows and I spent a lot of time in the mornings drying it off. The previous owner clearly hadn't bothered doing this and rot had started on the frames.
We've replaced the whole units with uPVC and the difference this morning to the condensation was amazing. None inside, loads of the outside surface. The house is still cold (although it will take days to warm up after dropping to 5 degrees inside during the work), but I'm confident it's not the windows fault now. I am not sure we'll save money on heating as the general heat loss in the old house is so large, but having better windows makes the house feel so much better.
My previous house was modern but which originally had poorly fitted double glazing. I replaced those windows and I saved money over only a few years, but the windows were really the big heat loss of that particular house. You could see the curtains moving when the wind blew.
We're very sad to see the wood go on an old house. If we had woodern frames in good condition then we'd have been looking at replacing just the panels.
25 year old house with wooded double glazed windows that were well past their best. Swapped out in 2022 for new UPVC windows. The difference is very noticeable, both in how much easier it is to heat the house and how much quieter it is. However...
I suspect the answer is “Not as much as spending the money on [your heating fuel]”
...this is probably true. House looks much nicer now though.
Can you explain what you mean by 'trim' in this context? I'd like to do this on our house as I suspect that a shoddy job has been done. 17 year old house.
Watching with interest. Just signed up to replace my 1980s wooden double glazing with new 28mm vika profile units.
I have been playing with my FLIR Cam and the difference between the modern upvc units on my extension and the original wood frame unit is mega on the heat loss via the FLiR so I can't see why the new windows won't make a major difference.
My wood frames are rotten though .... Not bad for 40+ years though.
Quotes ranged from 4k to 13k for similar looking 28mm double glazed or similar profiles tilt/turns with the largest window needing a toughened pane.
The 4k ones had some grim looking frames when playing with them so we went with the 6k as they came with vika frames
How good are you at DIY...
Fitting windows isn't all that hard (I've since found out) .
We got ours done years ago. We were probably fleeced somewhat.
A guy I work for was a salesman for a while. He could offer substantial discounts off the list price before he called the office. As long as they got the job with some margin. The office didn't care much.
You should be able to calculate objectively the heat loss for a 'best possible' replacement window and for your current windows.
A quick Google found this article -
https://www.h2xengineering.com/blogs/calculating-heat-loss-simple-understandable-guide/
But at expect more searching will get better sources of info including how the type of glass impacts performance.
I have similar windows to you in my house, mine are air tight and my working assumption that replacing them is not economically justified by any fuel saving. Plus on eco grounds on need to consider energy used in manufacturing new windows. If cared for wooden window frames have an almost infinite life, not sure if that is true of UPVC frames.
I have yet to do the formal calculations, on my to do list.
As a basis for calculations, estimates I see say 25% through roof, 35% through walls and 25% through windows.
They don't state what the baseline is - but assume 25% is from poor single glazed to top quality double.
Take your gas bill, knock off the summer months as a baseline for hot water and cooking and look at 25% of the remainder as your starter for best possible savings. That would be extremely optimistic so run it again at 10% saving and that's your bracket to look at for deciding on the financial part.
Something like that...
And me crawling through the subfloor void to fit insulation between the joists…
This is a job I now kick myself over. Half our floors are too low to get under - and yet we did not have the money when we renovated that area after we moved in - to do the floors now will be a pain...
The front half of the house though is on my 'maybe I need to go caving' list...but it wont be pleasant as most of it is about a 30-50cm space, on sand, to the joists above...
How would you get down there?
I'd love to.get under ours, there's a good 80cm but no acces. I'd have to make a hatch in the wall outside the house.
I’d love to.get under ours, there’s a good 80cm but no acces. I’d have to make a hatch in the wall outside the house.
Umm, cut a hatch in the floor? That's what I did.
I replaced secondary glazed double glazing with state of the art tripple glazing about ten years back. Yes it made a difference but nowhere near as much difference as any of the following: insulating the walls on the inside, insulating under the floor between the joists, insulating the roof to a higher standard. In terms of money saving PV and solar thermal had longer pay backs than insulation but faster than windows.
When I did the pay-back calculations not including my own labour everything paid back within 11 years except the tripple glazing which was probably never.
Ten years on energy prices have increased and things paid for themselves faster than expected, and we've benefitted from a house with much less condensation, a more uniform temperature and much reduced temperatures in Summer.
Can you hire, borrow or buy a cheap FLIR camera to see if the windows are your points of heat loss?
the roi on replacing double glazing purely from a money-saving perspective is non-existant. Even replacing old single-glazed windows with double glazing has a return period of somewhere around 25 years, so at best thats cost neutral, the couple of quid a year you'd save with triple glazing over double woudln't even pay the interest on the cost you're spending
The windows will be the bright areas on the Infra red image even if they're state of the art tripple glazing, I very much doubt you'd see the difference between the latest double glazing and twenty-year-old double glazing. You won't see the heat loss through the floor at all with an IR cmaera and most British homes have no insulation under the floor at all. Sure, heat rises, but it's only when you insulate the floor you realise how much heat you were losing before.
Yeah, if your loft insulation is below 'reccomended thickness' that's an easy and reletively cheap place to start for good gains.... basically a no-brainer, so to speak.
Friend of mines landlord recently put interior insulation on interior walls where practical/suitable.. makes a good difference and doesn't really make the room feel much smaller tbh...although you do obviously loose a bit of space, his house was quite cluttered so he de-cluttered at the same time and it really doesn't feel any smaller due to that.
I would echo what others said and refurb the current windows. If they are quite well sealed I wouldn't think you'd feel much of a difference if you replaced them all unless you had gaps all over the place.
When I insulated the walls I took out the radiators too which compensated the loss of space. I heat using a wood burning stove but an air/air heat pump blowing warm air would do the job just as well now heat loss is much lower.
A UK cavity wall with bead insulation in the cavity has an R value around 1.5. 100mm of polyurethane is R=4.5 and 100mm of wood fibre is R=2.6. 100mm to tripple the thermal resistance.
I chatted to some eco building folk about our house, and the advice I got was that windows wouldn’t make the most difference to heating costs but they make a big difference to comfort. The reason being that they have the biggest temperature difference with room temperature so you can feel the cooling effect they have on the air. Ours are also poorly installed (apparently fairly common in early 90s Inverness) so there are some huge uninsulated gaps between the windows and the walls.
We’ve ordered some fancy triple glazing for our worst offenders and are paying a specialist to install them. Might not be the best financial move but we’re confident it’ll improve comfort.
I had a rep from a Bristol based family company call and check out my windows. They were originally fitted when the house was still a council house, so budget driven. That was roughly forty years ago, and they were never very good - one back bedroom window never shut properly and you could hear traffic noise through it.
I was shown an example, and it turned out the actual frame is made by a company in Calne, when I worked for a print company there, and we did all their print. They’ve been going for twenty-thirty years, so well established. Several features stood out, three-way venting, plus the actual window can be pushed out at 90° so I can properly clean both sides of the opening part from inside the room, and I can easily reach the other side as well. They’re replacing 11 windows in total at a bit less than £10k. <br />As has been said, the outlay will never be recovered, but I’ll have decent windows for the first time in nearly half a century, so I’m ok with that. <br />There was a discount on that which helped as well. I’m also looking at new front and back doors too; what’s fitted are uPVC replacements for the original wooden doors, and while they were quality wood, they were what were fitted to the house when it was built, which is pre-WW2. What’s there now is OK. Ish. The house hasn’t had anything much done for years, so I think it’s now time.
I very much doubt you’d see the difference between the latest double glazing and twenty-year-old double glazing
Doubt away.
The hatch [s]we use to hide bodies[/s] left in the hall cupboard from an old central heating system update.
@molgrips There should be plastic or wood strips covering the hole between frame and wall on the outside of the frame. If your windows are reasonably modern these will be held on with mastic.
I can't for the life of me see any kind of removable trim. From what I can see, the frame seems to consist of a single extrusion which is recessed into the wall both outside and inside a good few cm. There is a hole in the inside of the frame where I'd been experimenting with closing blocks, and if I poke a 14/16 double butted spoke through I hit what seems to be solid PVC on the other side.
I had a little hatch in the floorboards in the understairs cupboard. Horrible job though, reminds me why I always stayed clear of caving.
I can’t for the life of me see any kind of removable trim.
Older installations don't necessarily have the trim. The windows I had replaced didn't have the trim (from 1994). The later ones did though.
I’ve searched and this would appear to be the best thread to help us. We’ve a small 1920’s semi, we’ve got cavity wall insulation and as much as 600mm of insulation in two thirds of the loft and 12 year old UPVC double glazing. Our house is actually quite warm in winter but in summer as the rear faces SW, it gets too hot. We’re contemplating replacing the patio doors with a triple glazed half size window and also the other windows too with glass that reflects heat away rather than allowing for heat gain. I know that this plan will be expensive but we’re trying to get the house into shape in a “love it or list it” sort of effort! Does anyone have experience of triple glazing or expertise in the advanced glazing available?
Last year we replaced our 25 year old double glazing. We got new triple glazing windows to the front of the house, this was recommended by the sales rep to reduce noise as the front faces a main road, the rear of the house was double glazed.
Did it make a difference to the bills? I'm leaning towards yes but no empirical evidence. It did eradicate condensation in the front and back rooms, reduced noise in the front and the windows have a much cleaner and nicer look. The new front door also has multiple locking points so feels very secure. It was a messy job and you end up having to sand and paint all around the new windows.
I also put my money where my mouth was.
New windows being fitted in 6/7weeks.
I had the wind coming in and at various points the rain because the windows are beyond their best.
Suspect I'll be seeing my benefits quickly.
Consider shading too. Shrubs, trees, climbing roses, a 'sail' etc. Replace patio with shrubs and ground cover. Add a pond. Think shaded and cool. Makes a huge difference.
I'm currently on a project around using nature based solutions to climate change - one objective is reducing overheating in schools. Glazing is the biggest issue...so hide it and the ground around a building from the sun and heat
Found the original receipts for the D/G that I’ve just had replaced, and it was done in two phases, ‘93 and ‘94. I was expecting mine to be done in March, but I had a call last Monday to tell me the windows had been QC’d and passed inspection, and could they start the installation tomorrow (Tuesday)! 😳
I arranged for Thursday, the scaffolders turned up Wednesday, the upstairs were all done Thursday morning, the downstairs Friday morning and the scaffolders came and took down the steelwork while the windows were being finished off. They were gone by lunchtime!
They’ve done a great job, watching them doing the downstairs windows I realised why the old ones were noisy - the frames were just fitted into the wall apertures, with a thin bit of plastic trim either side, the frames were set right on top of the wall cavities, with no other sealing! The new ones have thicker glazing units, the frames have draught barriers spaced throughout the frame cavities, and they squirted SoundFoam in between the frames and walls to give a draught and sound barrier, they used six big cans on my windows! The plastic trim around the frames themselves are about three times the width of the old ones. The difference is startling, the traffic noise from outside has dropped right down, it’s pretty much silent at night now, which I’m just not accustomed to after forty years!
The frame manufacturers are Deceuninck, who’ve been around for years, place I used to work at was just down the road, we used to do a lot of their printing, so I knew of their quality before I ordered them.
Nothing beats that new window feeling 🙂
had my windows changed on friday - lads did a quick and tidy job.
Went from 30 possibly 40 year old hardwood timber double glazing with 18mm glass.
The frames were fairly rotting and they had certainly been repaired in my tenure with a fair bit of fibreglass as well as being jotun demidekk'd every other year
since we insulated the eaves walls and coombed ceilings we started to suffer condensation on the windows due to removing hte fresh air ventilation passing through the living space(drafts) - which compounded the timber rot and through out the winter storms they were starting to pass water through.
fitted Vika profiled 28mm double glazing - double tilt and turn egress approved windows and matched the existing windows downstairs (low glass so toughened etc)
wiser usage and temperature monitoring says despite it being between -2 and -6 at night we have had the central heating on for less than an hour a day compared to 4 or 5 hours at night to maintain sleeping temperature in the kids room as we did most of the winter.
whole house generally feels significantly warmer* - and this morning we had condensation on the outside of the window :O
wouldn't expect to need to do any work on them in my life time anyway.
(*1950s build with cavity wall insulation / the rear of the house removed and extension that exceeds current regulations across the back - and the roof space is fully insulated to the best that it can be while maintaining required ventilation - Need to do the dormer cheeks when i have the tiles off the roof on the outside when i'm fititng the solar thermal panels.)
