Job application adv...
[Closed] Job application advice
My job is killing me so its time for a change, I have found the perfect opening however the application process is not what I'm used to, they don't want a CV or cover letter.
On the application form there is a section for relevant experience and a section for a personal statement (straight forward so far)however the application states that no experience is required as full training will be given.
In the experience bit do I list all of my previous experience that ties in with the stated essential skills in the advert and then use the personal statement to address the required aptitude/attributes?
Can I use bullet points for the experience to cut down on the use of blocks of texts?
help me STW.
Posted : 16/09/2017 11:05 am
Sounds about right. Factual list of relevant experience in the bit on the form. competency based answers in the supporting statement.
Ie person spec states " must have good knowledge of some fancy computer programme"
IN your supporting statement you write. "I have good knowledge of fancy computer programme. I used this in my job at x achieving this that and the other".
Address each point in the person spec in this way
Posted : 16/09/2017 11:14 am
Thanks tj.
Posted : 16/09/2017 11:18 am
You've got the right idea and TJ makes a great point! Best of luck!
Posted : 16/09/2017 1:00 pm
Thanks jamj, been at it all day. I want this to be perfect as my current job is making me ill ??
Posted : 16/09/2017 5:19 pm
I've been there too Pik n Mix. Fingers crossed for an interview and success!
Posted : 17/09/2017 10:16 pm
