Can you have too many clamps, is that a thing?
No, no it's not.
Mesmerising video @kayak23 and love the end product. Really need to move house so can have play space.
I've actually found a local woodworking course.
It is £21k which seems a bit pricey, not sure what the going rate is ......
For how long? Who runs the course?
Although it wasnt a serious post, the course does actually exist, details here;
https://chippendaleschool.com/furniture-making-courses/professional-course/
Surely they teach you how to use a swan neck chisel rather than a router on that course??
Oh yeah. Heard of them.
Great if it's in your budget.
If you're after learning more basics, there could be a college course, evening class or something instead maybe.
The college I used to work at does 4 evening classes a week alongside the daytime stuff.
No good to you in Warwickshire though.
Rather spend that cash on one of paul sellers classes if he is still doing them.
He is on YouTube if your interested.
I highly recommend his Christmas star project if your new to woodworking
Great if it’s in your budget.
I dont have enough limbs to pay for that.
I've triple checked the local Colleges and theres nothing within evening course reach annoyingly.
Seem to be in a bit of a blank spot unless travelling into Edinburgh which would cost quite a lot of time.
Just want to thank @intheborders for recommending that Makita Router/providing the link now I've had a while to use this thing.
Excellent little router and very easy to use.
If you've ever watched a video of a luthier building an acoustic guitar, then the answer is no, you can never have too many clamps 🙂
Slight hijack. I need to put up lots of shelves and cut them to size.
What’s best circular saw or jigsaw. By best I mean cutting a straight line and not my hand off.
Also ,cordless recommendations for either are welcome.
I only have very limited experience with jigsaws, but in my experience it's more about swapping to a new blade when it starts getting dull, and taking it slow and methodical.
Measure twice, cut once, as they say.
They cut pretty fast do you might want to modulate your trigger finger lest you go 'off piste'
Track saw would be best
As the baseplate of a jigsaw is straight, you can run it against a basic fence, which would be a straight piece of wood or mdf to keep the jigsaw on track.
If you are cutting mdf, this is fine, but if you are cutting solid timber, then a handheld circular saw is much better, as with a jigsaw, the thin blade tends to follow the grain and wander, leaving anything but a straight cut*
*As in the cut on top might follow the line, but underneath, the line might have wobbled all over leaving a ragged finish.
If using a circular saw. NEVER hold the bit you're cutting off. Use a fence on the saw, or a sub fence as above and keep both hands on the saw.
A common injury for amateur woodworkers is they hold the bit theyre going to cut, and curl their fingers underneath the board, which the saw then dutifully slices off.
I should ask how thick is the shelf, because mini circular saws are available, which might be safer for the diyer to use than a bloody great model.
https://www.ebay.co.uk/itm/183197296614?hash=item2aa768e7e6:g:lKoAAOSwsIZZm~Fu
This one is cheap,of reasonable quality and a depth of cut of 27mm, which should be good for most shelf cutting type jobs.
How to use a fence on a jigsaw -
https://www.youtube.com/watch?v=TEb7IdWbWKI&ab_channel=RocklerWoodworkingandHardware
https://www.amazon.co.uk/Makita-DSS501Z-Cordless-Circular-Blade/dp/B00KGT542Y/ref=sr_1_7?
I have one of these - brilliant tool, almost renders a handsaw obsolete, plus you can cut fairly decent mitres if take time to check angles. Unlike a more powerful mains saw, enough power to cut without it running away or kicking back. Also great for the DIY places that don’t offer board cutting and you need to get an 8x4 in your car.
I’d also add it would be difficult to get a good enough finish with a jigsaw for shelving - I only use them for rough-cuts or stuff you can’t see.
If you’ve ever watched a video of a luthier building an acoustic guitar, then the answer is no, you can never have too many clamps 🙂
For some reason that reminds me of Yvette Amos on BBC Wales Today.....
The shelves are for the stock room so they don't need to be pretty. I use loft boards as they are cheap and an inch thick.
I'd buy the Worx saw then, sounds ideal for that job, and only 60 quid.(use the voucher)
Says it comes with a parallel guide, so no need to faff about with a sub fence and once you've got the correct width, will make identical cuts to all the rest.
Anybody know if vevor routers are as good as katsu? Router plus plunge base, tilt base, fixed, fixed offset bases, 2 collars, dust extraction £61.99 less a fiver with code VVOFF, I'm tempted.
Vevor appears to be a Chinese company, listed as dissolved in UK companies house. That could mean little though.
Katsu seems to have a fair reputation, and prices are similar, so maybe better going with them rather than one few seem to know.
Katsu and or Vevor will likely be of similar quality, though shouldn't really be compared to the Makita brand they're copying.
Katsu and or Vevor will likely be of similar quality, though shouldn’t really be compared to the Makita brand they’re copying.
Even just the button feel when you're turning it on/off is noticeably cheaper-feeling on my cordless Katsu compared to my Makita that it copies.
Random Orbit Sanders, am I likely to see much return on spending £200 over £100?
Like the Router, I'm not seeing a need for cordless but good dust extraction is important.
With sanders the issue for extraction is whether they come with a useful round port for extraction or some weird shape that only the supplied daft little dust bag will attach to
beyond that the difference money will buy is differences in the size of the the orbit (which dictates how effective the tool will be at removing material rather than just smoothing a surface) and in some cases the ability to switch between two orbits for shaping and finishing
the 150mm sanders by metabo, dewalt, AEG, Mafell (and prob a few others) are made by the same company - all quite different looking but all distinctive for have a metal housing for the orbiting bit) and have the same mechanism inside which is switchable between a 2mm and 6mm orbit making them pretty versatile.
(actually a quick look suggests those machines have crept above your £200 ceiling - I’m sure I paid less than that for a AEG one but that was before covit / brexid)
If you can find one as it is i think older stock, look for a Dewalt D26410 150mm random orbital sander. Its a dual orbit, so has either a 6mm, for heavy sanding, or a 3mm for finer finishing. It also has integral extraction, so would be relatively dust free. It is around about £200, maybe a smidgen more- £220 or something like that.
Aye Dewalt seems to have real problems with stock availability across the board at the moment
As mentioned above
Dewalt D26410
AEG EX 150 ES
METABO SXE 450
all have the same innards with a selectable orbit - I've had both the AEG and the Metabo - the metabo has a better shaped port for dust - the AEG - at the time- was the cheaper option - had a slightly weird slant cut to the dust port which required a bit of pipe and tape to get a good connection. But it had a better way of selecting between the different orbit sizes - on the Dewalt and Metabo you select by pressing in a button and turning the sanding pad til you hear a click - but you can't see what size of orbit you've engaged by dong that
The metabo seems to be in stock at a keen price here:
When I spoke to someone on the Mirka stand at the Makers show last week he was clear that if you only used a sander now and then you might as well get a cheapie. Mirka, Festool etc. are worth it if you use them all day, every day because of their light weight and anti-vibration qualities (he said). I had an Erbauer but took it back (twice actually) because the velcro wore out. If you get a pad saver that should stop that happening and you can get a 125mm for £50. I bought a Makita instead for £100. No significant difference but no case with the Makita.
Oh, and get Mirka sanding sheets from Axminster. They last much longer.
That Metabo is almost bang on but it's only available as 110v
FFX have it in 240v for a smidge more
Mirka Abranet discs are great for improved dust extraction.
I've got a Mirka Deros which I love, but Peter Millard reviews a copy.
Good lord, dust extraction, that does improve the experience really quite a lot.
That's proven to be a good addition.
I’m going with the Metabo SXE 450
It does actually have quite a lot of work to do so figure it’s worth spending a bit more.
What exactly is it you're intending on sanding ?. I only ask because we didnt explore the belt sander option.
Worktop/desk, some parts of doors (with a detail sander), cabinets, and depending on how heavy it is, some skirting boards.
Possibly some smallish sections of wood floorboards, but if anything serious needs doing there I'll be off to HSS.
I "think" for the amount of material I'm expecting to take off. A belt sander might be too aggressive. A lot of this will be refinishing.
Rather than starting a new thread, I need a drill and possibly a jigsaw, and a router would be a nice to have..
I found this modular kit but cant seem to find it for sale anywhere - anyone reccomend something simmilar?
Just for light home DIY use, nothing too heavy:
https://www.blackanddecker.com/product/bdcdmt1206kitc/matrixtm-20v-max-6-tool-cordless-combo-kit-storage-case?tid=585826
Thanks
They are good for heavy stock removal, with something like a 40/60/880 grit belt. But you can get belts at a finer grit, im using 150mm (Makita 9911) If you're sanding hardwood like oak, its a handy bit of kit
@Matty.
Seems to be on sale in the US, as all the listings I can find are quoted in $$$. So maybe not available here. Price seems to equate to £200.
For a modular system, I reckon your best bet would be Ryobi. And they've got a hell of a range of tools.
Ryobi starter kit - £199
Thanks..hmm might look at second hand stuff, but that poses issues as might get duff batteries and I don't want to buy anything thats been nicked out of someones van!
Is there a tool club near you?
I have this just down the road... https://www.theecologycentre.org/tool-library
Jigsaw blades, do good ones make much of a difference?
I basically have no room for a bandsaw. So end up using a jigsaw for certain jobs and tidying it up afterwards.
E.g. I made some Gallows shelf brackets copying a shelf put up by the previous home owner, where the top of the wall facing part comes through a notch in the shelf, this raised part has a screw for mounting to the wall. This requires a notch cutting i to the shelf.
The blades I have are some dirt cheap B&Q jobs found in the shipping container tool emporium, the Jigsaw is an old but seemingly decent "borrowed" Bosch Professional thing. Am i going to see much of an improvement in cut quality with decent blades?
