Itunes/ipod help
[Closed] Itunes/ipod help
I wanna have a bunch of low bit rate mp3s (and videos) for my ipod AND same tunes lossless for playing through itunes/aiport express on my proper system in the house.
Is there an easy way to do this? Can I drag and drop the low q stuff & vids to the ipod without itunes, then just use itunes for the lossless?
TIA and apologies for numptiness, I just don't "get" itunes.
Posted : 14/10/2009 10:41 am
2 copies of the same file. 1 high bit rate, 1 low bit rate. Slightly different name to reflect bitrate.
Use a low bit rate play list in itunes to add the low bit rate tunes to the iPod.
use a high bit rate play list to play through iTunes.
Posted : 14/10/2009 10:45 am
Hmmm. Renaming the files could take ages, unless itunes/WMP can do this automatically?
Posted : 14/10/2009 11:04 am
how much bigger is a lossless file than a "normal" MP3.
25%, 100%?
Posted : 14/10/2009 11:07 am
I do something similar - I have 2 folders, one for MP3 and one for FLAC files. I rip all my CDs to FLAC, then transcode them to MP3, so I have the same files/folders under each main folder. I don't bother with ITunes though, I have Rockbox on my ipod so just drag and drop. I use BonkEnc for ripping/encoding.
Posted : 14/10/2009 11:08 am
Tim - My HQ VBR MP3s are about 1/3rd the size of the FLAC IIRC.
Posted : 14/10/2009 11:09 am
Something like this if you want to rename?
http://www.bulkrenameutility.co.uk/Main_Intro.php
Posted : 14/10/2009 11:29 am
cheers chaps ๐Ÿ˜€
Posted : 14/10/2009 2:39 pm
Rather than renaming them, you could use one of the song fields to label as high and low res - comments box perhaps. You could then put them into the relevant play list according to the entry there.
Posted : 14/10/2009 2:51 pm
You could have two smart palylists, and simply have one that says
Match the following rule:
Kind.....is....Loseless
Media kind is Not a video
And another that says
Kind is not loseless
and/or video
Then just sync that second playlist to the ipod.
(You could do the playlists by bitrate but im not to up on differnt formats and what not)
Just have a bit of a play and soon you'll get it perfected!
Posted : 14/10/2009 4:52 pm
