IT (windows 7) help...
[Closed] IT (windows 7) help needed please
My son has given me an old(ish) laptop running win7 but he's forgotten the password. How can I get into the damn thing to reset it?
Posted : 10/01/2013 8:01 pm
I recently bought a new PC with Win 7, set up everybodies accounts, set up my account giving myself admin previleges etc using a password I use for a couple of other things - must have typed it incorrectly twice and was locked out of admin privileges - d'oh! Tried a couple of simple things which didn't work, in the end I used [url= http://trinityhome.org/Home/index.php?content=TRINITY_RESCUE_KIT____CPR_FOR_YOUR_COMPUTER&front_id=12&lang=en&locale=en ]Trinity Rescue Kit[/url]
Walkthrough -
Pretty easy to do, it worked.
Other obvious solution is to re-install Win 7
Posted : 10/01/2013 8:17 pm
See of any of these will trigger his memory?
a favorite food?
your home or office address?
a frequently dialed telephone number?
something from your childhood?
a favorite number or set of numbers?
your name?
the name of a friend, family member, or pet?
a loved one's birthday?
a combination of any of the above?
Posted : 10/01/2013 8:18 pm
The password to get into Windows? you can't but if it has a recovery partion you can reset it to factory defaults by pressing one of the F keys at startup. You will have to find out what laptop it is
Posted : 10/01/2013 8:19 pm
I've used this at work to change local admin passwords before:
[url= http://pogostick.net/~pnh/ntpasswd/ ]http://pogostick.net/~pnh/ntpasswd/[/url]
It can reset the password to being blank on almost all common Windows versions unless the drive is encrypted. Take care as it uses a Linux boot CD and hacks the password database using a command prompt based tool. I've not managed it yet, but it is possible to completely screw things with it. ๐Ÿ™‚
Posted : 10/01/2013 8:33 pm
Going to look at the recovery partition option as cannot get in to system to use downloaded options. Yhanks for the help but I'm still stuck!
Posted : 10/01/2013 9:13 pm
You don't need to get into the system to use downloaded options, if you've got another pc you can use that.
Posted : 10/01/2013 9:40 pm
Tell me more please Bimbler; I can't access the desktop or use F8 system restore without password. Tried loading xp pro on instead but install says it can't locate a hard drive, even though the laptop seems to work fine.
Posted : 10/01/2013 10:56 pm
Sounds about right, IIRC a win7 partition will be a bit iffy for winXP to see.
As bimbler says you will need another machine to download the Trinity rescue kit
Posted : 10/01/2013 11:01 pm
genghispod - Member
Probably uses AHCI SATA, therefore F6 drivers are required, or changing SATA mode to IDE in the BIOS (but this makes the disk performance worse).
Posted : 10/01/2013 11:03 pm
Watch the walkthrough and follow it step by step, you need to download Trinity Rescue Kit on a different PC, create a bootable USB/CD (you may have to go into the BIOS of the laptop in order to boot from USB) and away you go. It seems a bit hardcore and has I guess has the potential to mess things up but follow the guide and you can't go wrong.
Other option find a Win 7 disc of the same flavour as already installed on the laptop and reinstall the OS - there should be a Win7 product key sticker on the laptop.
Posted : 11/01/2013 10:38 am
