IT techy help! IBM ...
[Closed] IT techy help! IBM Thinkpad query
Hi,
Any IBM Thinkpad literate techies on-line?
I've got a T40 which has a S-VHS socket. Is it an Input only or Input/Output interface?
If it Outputs how can I configure it to connect to my telly which has a S-VHS input?
John
Posted : 29/05/2009 5:20 pm
Have you tried pinging it?
Posted : 29/05/2009 5:22 pm
CF, they say a little knowledge is a dangerous thing! ๐Ÿ˜‰
Posted : 29/05/2009 5:24 pm
That makes me positively lethal.
Posted : 29/05/2009 5:28 pm
It'll almost certainly be an output. You need to connect an S-VHS cable from laptop to TV. There will then be a key combination or an application to switch-on the S-VHS output. On my thinkpad, it's Function Key + F7 to toggle between different video outputs. Alternatively you might need to go to the graphics adapter utility and enable the option there.
Posted : 29/05/2009 5:35 pm
Cheers dc.
Swapped the 2nd output device in Displays from ext monitor to TV and it's working fine.
Posted : 29/05/2009 5:48 pm
