I.T. help required ...
[Closed] I.T. help required please (internet connection)
When trying to connect to the internet, i'm starting to get "ERROR 756 connection is already being dialled"
I haven't changed any settings, and when i check what other programs are running, there arn't any!
If i disconnect the modem & reconnect, it will work ok.
Any ideas please?
Posted : 14/01/2010 12:33 pm
Dialled? Modem?
Are you from 1987?
Posted : 14/01/2010 12:34 pm
Broadband, sorry, technophobe here.
Posted : 14/01/2010 12:38 pm
Who is your ISP?
Ignore this^
Edit: I actually thought this error only happened with dial up modems. Can you disconnect any dial up services in the network settings?
Posted : 14/01/2010 12:39 pm
756 - This connection is already being dialed.
This error indicates more than one simultaneous request to make a dial-up networking connection has been made.
This can occur if you have one or more programs set up to automatically make a connection to the Internet. Check the settings for your e-mail, browser and other applications that access the Internet, disabling automatic connection as appropriate.
Posted : 14/01/2010 12:40 pm
AOL?
Tiscali.
Will check e-mail settings now cheers.
Posted : 14/01/2010 12:42 pm
Yeah in Internet Exploder check under Options->Connections
You'll probably have something under "Dial-up and Virtual Private Network settings". Get rid of it.
Posted : 14/01/2010 12:48 pm
Hmm, can't find anything which would automatically try to connect.........
Posted : 14/01/2010 12:50 pm
OK Graham S,
i had "Tiscali Broadband (default)"
And "broadband connection"
Have deleted "broadband connection"
Lets see if that works, thanks.
Posted : 14/01/2010 12:55 pm
Did it work? Or have you now fallen off the Internet completely and are unable to reply?
Posted : 15/01/2010 1:21 am
