IT bods - I need so...
[Closed] IT bods - I need some help
Is there any way to retrieve data from the HDD in a laptop with a knackered screen?
Posted : 09/01/2013 8:44 pm
Might auto switch to the external VGA if you connect it to a monitor and turn it on ad operate it normally
Or you could use HDMI?
Failing that buy a cheap USB caddy and stick your hard drive in it and get the data off from another PC
Posted : 09/01/2013 8:46 pm
Yeah take the hard drive out and pop it into a hard drive caddy, you should be able to connect this via usb to another computer and get the data off.
Posted : 09/01/2013 8:48 pm
Long, long time ago...
... one of the Function keys would toggle between lappy screen and a plugged-in big one. However I can't remember which, and have no idea if it's still true.
Posted : 09/01/2013 8:49 pm
Thanks for quick response, we tried the VGA and HDMI routes hoping it might auto switch, it didn't unfortunately.
Are the USB caddies easy to get hold of?
Edit - Google and Amazon are indeed my friends, I'm guessing its a 2.5" SATA drive
Many thanks everyone. Now likely that my son will not be allowed access to my daughters computer.
Posted : 09/01/2013 8:50 pm
do you have a little projector or screen hotkey ? (mine is F4)
I can plug my Telly in while the Laptop is on via HDMI and it comes to life if I tap this hotkey.
edit slowoldgit beat me to it
Are you sure screen is gone? Lappy might be making all the right noises, buut not actually working.
2.5" caddies are readily available
.Make sure you work out what kind of connection your HDD has
Posted : 09/01/2013 8:54 pm
Try connecting the screen before turning on the laptop as by default if it's connected before power on it should output the monitor if you close the lid quickly after pressing the power button.
Is there a Maplins near you? they do a good range or relatively cheap caddies.
Posted : 09/01/2013 9:13 pm
