Is this knackered? ...
Is this knackered? [Showertrackworld]
No. 1 spawn announced this morning that the electric shower isn’t working properly.
It’s an Aqualisa unit, what happens is that it cycles from a feeble flow, to kettle noises, to a decent/normal flow, then shuts off, then the whole cycle restarts.
Anyone any ideas what’s going on, is it potentially repairable, or am I looking at replacement? If the latter, is it likely to be the plumber, the electrician or both?
Thanks all!
Posted : 07/06/2025 2:36 pm
It sounds borked.  Not sure whether I’d rather have a plumber messing with electrics or a spark messing with water myself 😂.
Seriously though, they’re not that hard to DIY, but if you’re not up to the task a reasonably competent plumber would be my shout.
Posted : 07/06/2025 4:09 pm
Is there a filter mesh on the inlet that might need clearing perhaps?
Posted : 07/06/2025 4:12 pm
Airlock is worth looking into as well. There is a walk through of how to fix that on their website iirc from when ours had a wobble.
Posted : 07/06/2025 4:29 pm
I’ve changed around 500 electric showers. Its knackered, get a new one. They can be repaired, but the parts are expensive, other things can be on their way out too, so it is usually sensible to get a new one rather than try to fix an old one.
To save difficulty fitting it, try to get one of the same make/model. If you cant get one, look at where the water and cable come in, and try to get one that has the same internal layout, and, it should be a straight swap, whcih can be done in 15 minutes or less.
Posted : 07/06/2025 5:43 pm
Thanks all!
Posted : 07/06/2025 8:08 pm
You can get replacement showers that are designed to be flexible, ie you can choose where the pipework comes in. Last time I had to buy one I got one from Screwfix, something like this https://www.screwfix.com/p/triton-t80-easi-fit-white-chrome-9-5kw-electric-shower/5766t
Posted : 07/06/2025 8:36 pm
Fairly easy to do - main issue is finding the water cut off for the feed, otherwise it's off at the mains.
Posted : 08/06/2025 10:31 am
If it's a house supply off job install one of these in the pipework feeding the shower for the next time.
https://www.screwfix.com/p/flomasta-full-bore-isolating-valve-15mm/46860
Posted : 08/06/2025 2:05 pm
Posted by: fossy
Aye, pay someone else to do it. You completely overestimate my lack of skill or interest in DIY 😛
Posted : 08/06/2025 3:29 pm
