Is there an app for...
[Closed] Is there an app for 5s that reads resets car fault codes
Can any one recomend an app for iPhone that works like a car diagnostic tool
I'd want to reset / clear fault Codes not just read them
Posted : 27/11/2013 8:38 pm
Unless your cars diagnostics work by bluetooth, you'll need a way of connecting the iphone before you need an app
Posted : 27/11/2013 8:40 pm
A lad a work showed me a Bluetooth widget available on eBay they plugs into an OBD2 port but I didn't see an app for apple, just android and windows.
Duno if this link will work as I am on my phone
Bluetooth Super Mini Android ELM327 OBD2 OBDII 1.5 Car Diagnostic CANBUS Tool UK
http://bit.ly/1cOjA6S
Posted : 27/11/2013 8:43 pm
Blue tooth bit is easy , but as above all I found was windows/ android stuff
Posted : 27/11/2013 8:46 pm
You can buy tools to do what you ask for between 6 and 30 quid depending on car. Why does it need to be done by your phone specifically ?
Could you do Bluetooth to a laptop or netbook? Most come with a disk and computer program.
Posted : 27/11/2013 8:48 pm
The cheaper tools seem to be car or at least make specific
An app seemed a nice easy way to go about it
My laptop died and not seen the point in replacing it
Posted : 27/11/2013 8:49 pm
Didn't realise (mostly cause I didn't think there was a need for) that you could easily get a bluetooth adapter
trail_rat - Member
many of them are utter-garbage though. E.g mine will only give a code of 01/01 N/A..... useful
Posted : 27/11/2013 8:50 pm
Aye well if you buy with your eyes closed 9/10times youll get shite.
Research. , mines works fine with obdII cars , diagnosed a buggered cps and a lambda as the reason my mates car didnt run and that my trucks fuel pump wasnt buggered ๐Ÿ™‚
But many faults with cars wont register a fault or can trigger a false code so following a code reader blindly is an expensive game.
Posted : 27/11/2013 8:55 pm
trail_rat - Member
So what happens if you buy one recommended by a popular intarweb forum and its still shit?
Nice assumption though
Posted : 27/11/2013 9:03 pm
Maybe. I should ask what stand alone reader is best on a budget
Posted : 27/11/2013 10:16 pm
You can get Bluetooth OBD2 widgets, but because of Apple's locked-in Bluetooth, most of them won't work with the iPhone. You can get WiFi OBD2 widgets too, and they do work.
The best app is DashCommand, but it's not cheap - look on the App Store for OBD2 to find others.
Posted : 28/11/2013 1:43 am
