That sounds a little bit moronic, I do know there's a volume slider! Let me explain...
On the turbo, I've been watching ripped TV series on VLC, because it goes a lot louder than other playback apps I've used. The laptop seems happy enough with that. But watching Netflix, with everything maxxed out, it's generally a lot lower. So I figure I could get a cheap inline amp but that shouldn't be neccesary, the PC can be loud enough, it just doesn't seem to have a setting to turn it up to 11!
Any ideas? Ideally, free and simple ones. First person to suggest linux is getting an opensourced chinese burn.
d'oh you need a mac....
http://enenews.com/computer-tip-raiseboostincrease-volume-above-100-when-windows-7-photos
possibly one of these, depending on your sound drivers etc. I get a 200% range by default on most of mine
if that does work it was found by doing this
http://lmgtfy.com/?q=increase+pc+volume
Can you go into system, sound/audio and increase the db , it's usually a vertical slider. I'd been Mac for 15 yrs so don't know exact pc procedure.
