Ugarizza - it might! Here’s what chatgpt says:
Is it ever correct to write witness’ ?
Yes, it is sometimes correct to write "witness’" with just an apostrophe without an additional "s" when indicating possession. This is known as the "singular possessive" form. The usage of "witness’" without the "s" is more common in older or more formal writing styles.
Both "witness’s" and "witness’" are considered acceptable, but the choice between the two forms may depend on the style guide being followed or the preference of the writer or editor. Some style guides, such as the Associated Press (AP) style, prefer the use of just the apostrophe for singular nouns ending in "s" to indicate possession, while others prefer adding an "s" after the apostrophe.
In less formal or everyday writing, using "witness’s" with the additional "s" is generally more common and may be considered more standard in modern English.
I saw witness memory as a compound noun such as random access memory, perhaps because I used to spend time in court where it was used as such. If talking about a general case then the plural witnesses' would also work. What doesn't work for me is witness' memory without "the/a" indicating singular.
Poly alludes to "extra effort". We're all capable of rushing something out and equally capable of doing a lot of background reading then spending time to get it right. In the past that meant a Thesaurus, a dictionary and a grammar book - then proof readers. Four people proof read a critical letter my son had to write. He wrote a damn good letter, Madame and I proof read and commented, a secretary with excellent French proof read it, his economics teacher read it. Once Junior had integrated all of the corrections and suggestions a good letter was simply briliant - no plagiarism.
No plagiarism, but also not entirely their work. As a learning exercise, almost certainly improved by the external input; as a testing exercise (presumably this example wasn't), made less accurate.
In my view, the OP's situation is definitely tricky, but might possibly have been made easier if they'd been able to make it clear that various forms of external input (ranging from spell-checkers to AI) are actually varyingly acceptable in a learning exercise, and that the teacher wants to understand what was used here in order to do their job of teaching well, not to prosecute a crime.
I don’t have a turnitin account. Some one on here must. I’d love to see what it produces
I’m now lost as to what this piece of work is. If it’s prep for an exam is ai against the rules?
AI is just a calculator for words.
It's a Tool. Use it 🙂
No crimes have been committed
You don't know that, now you have confronted them, they could be out on a killing spree eradicating witnesses and burning the proof.
Tutnitin is currently unable to detect ai-generated text (we’ve checked). ChatGPT keeps a record of text it has generated so detect this in submitted work.
Apparently, the way to get around the Ai bot looking obvious is to use Google translate in and out a different language then back to English.
Translate apps are so good these days that it will come back virtually unchanged
I’ve had good comprehension of language from as far back as I can remember, and I can, and have used terms like ‘et al’, knowing where to use them from context; however, if asked to explain it, I couldn’t, mainly because I can never remember stuff like that, knowing it’s correct in the context generally gets me by. But then, I’m not writing an essay in criminology as a piece of coursework.
They claimed they used an online thesaurus.
Hold on, they would have to understand what concept or idea they were trying to communicate in order to use a thesaurus in the first place, in which case they’d have learned the meaning of the word in context at the time, and wouldn’t be flummoxed when questioned later…
I was thinking that, to use a thesaurus correctly, you have to know how to use it, and what to look for, as ☝🏼
Maybe this entire thread is a criminology experiment set up to be analysed by the AI. I wonder how we’re doing…
That’s the thing, perhaps the AI are now smart enough to be postulating a problem like this and using the STW hive mind as a human processor in order to learn to be even more efficient and effective.
Makes you think…
Someone pointed out it could have just been processed by Grammarly or similar, anyone got any thoughts on that?
I asked about grammmarly- they said they hadn't used it. Just an online thesaurus
It's preparing for an exam. An open book exam they can take this piece of work into. They need to sign a declaration that it's all their own work. This is supposed to be all their own work.
Makes you think…
Maybe I'm the next level of ai, complete with terrible spelling and proofreading. Maybe I don't even know it 😀
If it seems a bit 'off' it probably is. Proving it, is a different matter.
So don't die on a hill, without a very good reason.
In year 13 nothing is all your own work. Nothing is original research, it's all a literature survey that is rehashed into an essay. Your student hasn't got the means to sit of benches in court rooms and do original research into the behaviour of witnesses. Even in latter life when you go on to do your own work the first thing you do is a litterature survey to assure yourself that you aren't simply repeating what others have done, you take pre-exisiting knowledge and build on it. At every step you acknowledge what people have done before you with references. Plagiarism is taking the work of others and claiming it as your own. If you can't find a source your student has copied word for word it's not plagiarism, it's a literature survey, and that's what you've asked for. If it's well written by whatever means then so much the better.
IMO allowing students to take anything beyond a pen into an exam room is destoying the level playing field. Your system is open to abuse that you have no effective way of policing, change it. Your current attitude smacks of an inquisition.
If you can’t find a source your student has copied word for word it’s not plagiarism,
It's unproven, which is the point of the thread.
So it's an inquistion, a witch hunt, "we've absolutely no proof but we'll accuse you all the same and put you through the mill". It's character assassination, harrassment, and all that on a legal course. Madame was subject to academic harrassment on a PGCE course, very upsetting, we noted everything and wrote a very good letter of complaint - we won, a head rolled, but it was all so unnecessary. IMO You should back down and apologise, Tall_Martin. You have failed to prove anything, nobody here has been able to prove anything either, time to end the witch hunt.
So it’s an inquistion, a witch hunt, “we’ve absolutely no proof but we’ll accuse you all the same and put you through the mill
Get over yourself. The OP has a reasonable suspicion based on the student's previous work, so asked them if it was their own work, and asked here for help. As others have noted, the OP will need to let it slide but think about ways in which coursework can be assessed that reduce opportunities for cheating.
Mark the work.
Note as suspicious in your opinion.
Add a note saying if it's ever proved to be copied it will be revisited.
Ultimately the students loss in long wrong, probably not.
Those types always seem to do OK .
Move on Sherlock, case over.
So it’s an inquistion, a witch hunt, “we’ve absolutely no proof but we’ll accuse you all the same and put you through the mill”. It’s character assassination, harrassment, and all that on a legal course. Madame was subject to academic harrassment on a PGCE course, very upsetting, we noted everything and wrote a very good letter of complaint – we won, a head rolled, but it was all so unnecessary. IMO You should back down and apologise, Tall_Martin. You have failed to prove anything, nobody here has been able to prove anything either, time to end the witch hunt.
Get a grip.
At no point has the op mentioned doing anything other than questioning the student about the disparities in their work which is absolutely standard practice.
Get a grip.
At no point has the op mentioned doing anything other than questioning the student about the disparities in their work which is absolutely standard practice.<br /><br />
Perhaps, but he’s already agreed the “sanction” with the head of faculty and head of year (who would presumably have been the person she might turn to if she felt his decision was wrong, which means they can hardly by independent arbitrators of any dispute). He’s posted extracts of a students work on an unrelated internet forum, he’s run a very unscientific experiment to prove this one essay is an anomaly and seems more certain now it is dodgy than when he first posted despite people pointing out the irregularities with it having been entirely AI’d.
The OP will be familiar with the concept that quasi-judicial processes need to not only be fair, but appear to be fair, and I think if he was to sit down with the student, her parents, his head teacher, and an impartial observer who had never met any of them and talk them through both what he has done and the certainty of his convictions he’d get some raised eyebrows. Now it might change when everyone reads the full examples of both old and new work and “cross examines” the student but we only have the OPs account of those processes. Edukator and I are saying, be careful, because it’s starting to look like he wants to prove himself right at all costs. Judge, jury and executioner.
I appreciate that schools and school discipline are not court rooms and subject to the same rules, but there does become a point when the consequences are so severe that the normal rights of everyone to a fair and independent tribunal will apply. If someone is being disqualified from an A-level course, with the potential that it changes university entry and therefore whole career and life paths, that’s a hell of a lot of power for one teacher to hold with no fair and independent process for review. Of course, the flip side is also true - if she’s making a signed declaration that the work is all her own and it’s not, for her own personal gain, then she is potentially not just sitting on the naughty step for telling fibs but committing fraud.
I'm viewing this as a teacher who is delighted when students produce work that shows they have learned to adopt an appropriate register. Each field has its vocabulary and linguistic style. People who succeed in life learn to master many registers which are appropriate in different situations (Brownlow et al. can't remember the date). Reading the text it strikes me that that the student has identified and uses the language codes used in criminal research, but not perfectly, which means it reads well but not perfectly and has a few errors. They might not yet fully understand the nuances of all the words they use (how many of us do?), but they're doing their best with their current level of linguistic ability and understanding.
When we learn and adopt a new register we can impress and surprise people. As a teacher we should encouraqge this rather than jumping to the possibly inaccurate conclusion that it's not the student's own work. In my own life I've had to learn to use a variety of registers in different languages. It's opened a lot of doors for me. My son does it better, more registers in more langauges; equally happy teaching kids to ski as negotiating a contract or dining with the boss of a CAC40 company.
Tall_Martin claims this work isn't the student's own language. I'd argue that it's becoming their language and they're getting better at it, which means that Tall_Martin's teaching is having the desired effect.
In all honesty I winced reading your interrogation in inverted commas Tall_Martin and found the idea of faling the student because of your suspicions (they are no more than that) disproportionate.
In my view the main problem is that you have a system that is open to abuse (your fault) and you have no way of knowing if it's being abused beyond plagiarism checking algorithms (which show up negative).
The whole affair is a pedogogical disaster. You have got into conflict with a student making unsubstatiated accusations and grilling them to the point of harassment, and made actual or veiled threats. A relationship based on trust has broken down. Imagine how the student feels about all this especially if they are being honest. It's never pleasant been acused of lying lying and cheating, especially when you are innocent.
I note the STW insults have started: "get and grip" and "get over yourself".
I'm as qualified as anyone on this thread to comment, that should be apparent from the language I'm using. 😉 And no, my contributions are not plagiarised, I really do understand this stuff.
I believe you: AI would pick up your spelling mistakes.
I note the STW insults have started: “get and grip” and “get over yourself”.
You started us down that road with your accusations of character assassination and witchhunts by the op. Absolutely zero evidence of that and a total overreaction. When I say 'get a grip' I mean try to keep a sense of perspective and recognise that we have absolutely no idea how this situation has actually been handled.
It’s never pleasant been acused of lying lying and cheating, especially when you are innocent.
Perhaps consider extending that to your fellow forumites by not accusing a fellow professional of witchhunts against a pupil?
What would Post Office Counters do?
They are great at false accusations 😉
Hi thanks again for all the help.
I think the fundamental answer to my question can I prove they are cheating is no.
I was certain it was not their words when I read it. It looked, and still does, like a mash of someone else's writing with my student adding some of the case studies from the course correctly. I am fairly sure it's ai, but now certain I can't prove this.
I hope my student takes the time to put the work in their own words and passes the course.
I'll take the advice from @mattyfez
If it seems a bit ‘off’ it probably is. Proving it, is a different matter.
So don’t die on a hill, without a very good reason
I'm absolutely confident the pasted work at the start is not theirs. I won't be putting up work that I'm mostly certain was their own work on here
The suggestions of a meeting with them, their parents and the head of sixth is an excellent one.
Tall_Martin claims this work isn’t the student’s own language. I’d argue that it’s becoming their language and they’re getting better at it, which means that Tall_Martin’s teaching is having the desired effect.
If any my students left my care with writing close to this standard I would be absolutely delighted.
Unfortunately, the student has not handed in a single piece of work to either teacher since September. 26 missed deadlines including resubmissions. So it's not the feedback from criminology that's suddenly improved their writing.
The way the qualification has been put together is the exam boards choice. I've been delivering it as per the boards instruction.
The qualification is having it's funding removed in the next round of a post 16 reforms. I'm a bit sad as it's interesting to teach. Currently there won't be a Criminology course from 2026. Their might be a policing qualification to replace it. I'm tempted to retain as an itc teacher. Or leave teaching again.
There are 4 typos I've spotted on rereading, Ransos, others that I haven't spotted are spelling mistakes. 😉 There's a comma missing too. If this were important to me I'd run a spelling and grammar checker, and get Madame to proof read it. If it were really important I get Junior to read it and dig out an ageing copy of La Bonne Correspondance for inspiration.
Valid points, Spin, I'm aware of what I'm doing, it won't sabotage Tall_Martin's career, or leave him with a grudge against teachers or even against academia in general. It might sow doubts about how he's treating his student and his pedagogical methods though, I hope so. Everything I've written I'd happily put my real name to and show to every student I've ever had and every academic boss I've ever had. Would Tall_Martin happily show this thread to the girl and her parents? I think not.
There are 4 typos I’ve spotted on rereading, Ransos, others that I haven’t spotted are spelling mistakes. 😉 There’s a comma missing too. If this were important to me I’d run a spelling and grammar checker, and get Madame to proof read it.
Not sure what your point is: you said your post wasn't plagiarised, and I said I believed you.
I haven't read the whole thread but there is a thing on the BBC website about this:
"I ran the essay through AI detection software. Within seconds, Copyleaks displayed the result on my screen and it was deeply disappointing: 95.9% of the text was likely AI-generated. I needed to be sure, so I ran it through another tool: Sapling, which identified 96.1% non-human text. A third confirmed the first two, but was slightly lower in its scoring: 89% AI. So then I ran it through yet another software called Winston AI. It left no doubt: 1% human. Four separate AI detection softwares all had one clear message: this is an AI cheater."
Not read it all , but I would imagine schools need a policy on how to deal with this sort of stuff ?
I can’t see how you can stop it, but can only imagine it’s discussion about how the inter web can give you all the answers you ever want but it won’t help you learn / improve your understanding of the subject, which is kind of handy if you want to pass an exam
Our 13yr old got a mate to go on chat GPT for some of his homework. When we read it we knew it wasn’t his writing. Just quizzed him on his understanding of the subject and he couldn’t answer, plus then asked him how he thought he would answer the question in an exam
From the article WCA linked.
Labyrinthian mazes
Just shows how superficial AI output can be. It caught the judge's attention because it is an obvious tautology, it simply feels wrong.
AI is just going through the motions, throwing chunks of text together that appear, on the surface, to fit. It's not driven by the writer's need to express a concept, but by which words thousands of other writers have put next to each other in the past. Eventually, it will be mostly plagiarising AI-generated content, layering blandness over blandness.
As you try to express an idea in text, that process often subtly modifies the idea itself, refines it. It helps you rehearse the best way to express it verbally or in written form later if needed. If you actively avoid that process by handing it to an algorithm, you're basically robbing yourself.
Thanks- multiple checkers might help
The school and exam board have policies in place.
Still don't think I can prove AI use, but hopefully having the consequences of its use pointed out in detail will deter the students from using it.
It might not be his own words but rereading it I don'tthink it's AI generated as it's not good enough. Sentence two could be improved by adding one word, and the 'flow' into sentences 3 and 4 is reliant on the question to make sense, and have context.
For example...
Psychological studies including research by lotfus et al, indicate that factors like the timing of the event, discussion with others, the passage of time and questioning methods in court can influence witness’ memory and testimony. This (this what - AI would be more specific) casts doubt on the validity of eye witness evidence, as memories may lack accuracy, especially over extended periods or in heightened focus on specific details such as ‘weapon focus’.(Next sentences are lovely, but what's the oontext to the two previous - complete jump) In complex technical cases, the outcome frequently depends on the testimony provided by an expert, be it a medical specialist or a forensic scientist.(so what) Essentially, these experts are expected to possess superior knowledge in their respected fields compared to legal professionals or laypeople, like jurors (again, context with the first two)
Not AI I think, but rigorous googling. Plus the spelling and imperfect punctuation
Labyrinthian mazes
Just shows how superficial AI output can be. It caught the judge’s attention because it is an obvious tautology
It's not, it's an oxymoron. A labyrinth and a maze are different things.
I'm interested by the fact that in the test above, the checkers were 99% sure that the AI piece was AI generated. Whereas the student piece is iirc, about 50% certainty. On that basis, I'd be sceptical because of the improvement that TM has seen, but seems likely there is still quite a bit of student (or at least, human) input. Which begs the question about what sort of help is reasonable.
When I did o levels (yes that long ago) we all had access to books that dissected Shakespeare's plays, identified key themes, and provided suggested examples and quotes. Indeed, is this not what a teacher does, albeit hopefully not quite as passive, so the students discuss and see where they get to prompted and guided by the teacher and others.
I can see that "write me an essay on.... might be considered abusing AI, but is "what are the key themes of Hamlet and how does Shakespeare show them...?"
Also - how reliable is AI? On a Wedding Present fan site elsewhere on the web, someone asked AI for a brief history of the band and got 75% nonsense. It's a brilliant read mind, I'm not sure Bob Mortimer didn't have a hand in it, not least for the hilarious names of the founder members, David Gedge (true) and Keith Estates (er....no)
I’m interested by the fact that in the test above, the checkers were 99% sure that the AI piece was AI generated. Whereas the student piece is iirc, about 50% certainty
I'm reasonably sure the student correctly added the case studies into chunks of ai generated language.
It is not all their own work- I'm 100% on that.
I can't 100% prove the above- I'm sure on that.
I thought AI generated stuff on our criminology course would be garbage. The stuff turned in was excellent. ,
The thread has reminded me of a story about Graham Greene. Allegedly he entered a writing competition in which the entrants were required to 'write a short story in the style of Graham Greene '
He came second
Let's say the claim made in the BBC article by the AImonger, Turnitin is correct and it has 1% false positive results. With ten written pieces to mark per course year then by the end you could be investigating, accusing or wrongly shaming a tenth of your cohort. Over a three year course, thirty per cent? There isn't an institution in the land that can handle that administratively, nor cope with the effect on admissions once word gets around of the academic atmosphere and dropout/failure rates.
The thread has reminded me of a story about Graham Greene. Allegedly he entered a writing competition in which the entrants were required to ‘write a short story in the style of Graham Greene ‘
He came second
The version of this I heard was that Charlie Chaplin once came second in a Charlie Chaplin lookalike contest.
My great uncle went to a fancy dress party and Graham Greene was dressed as Charlie Chaplin
True story
Online education has become the norm for many students and teachers due to the COVID-19 pandemic. However, this also poses a challenge for maintaining academic integrity and preventing cheating on tests. How can you tell if your students are cheating on online exams? And how can you prove it?
There are many ways that students can cheat on online tests, such as using Google, study websites, cheat sheets, unapproved tools, or copying from other students. Some of these methods may be more obvious than others, but they all violate the rules of academic honesty and fairness.
One way to detect cheating is to use machine learning techniques to analyze the students’ test scores and performance. Machine learning is a branch of artificial intelligence that can learn from data and make predictions or decisions. For example, you can use machine learning to compare the students’ test scores with their previous grades, assignments, and quizzes, and identify any abnormal or suspicious patterns. You can also use machine learning to check the similarity of the students’ answers and detect any cases of plagiarism or copying.
However, machine learning is not a perfect solution and it may have some limitations or errors. For instance, some students may have legitimate reasons for improving their test scores, such as studying harder, getting tutoring, or having a good day. Some students may also have different writing styles or use different sources of information that may not be detected by machine learning algorithms. Therefore, you should not rely solely on machine learning to prove cheating, but use it as a tool to support your judgment and evidence.
Another way to prove cheating is to use authentic assessment methods that are more difficult to cheat on. Authentic assessment is a type of assessment that requires students to apply their knowledge and skills to real-world problems or scenarios, rather than just recalling facts or information. For example, you can use case studies, scenario-based projects, or word problems that are relevant to your course content and objectives. These types of assessment can measure the students’ understanding, creativity, and critical thinking, and also engage and empower them to demonstrate their learning.
Authentic assessment can also reduce the incentive and opportunity for cheating, as the students have to produce original and meaningful work that cannot be easily copied or found online. Moreover, authentic assessment can enhance the students’ learning experience and motivation, as they can see the value and relevance of their work and receive constructive feedback.
In conclusion, cheating on online tests is a serious problem that can undermine the quality and credibility of online education. However, there are ways to detect and prove cheating, such as using machine learning techniques and authentic assessment methods. By using these strategies, you can uphold the academic integrity and fairness of your online courses and tests, and also improve the students’ learning outcomes and satisfaction.
The above, just reads like it was ai generated, something to do with the typical structure Was this the point perhaps? Interesting discussion though, things are going to get weird fairly quickly in all forms of written content.
'Too perfect' appears obviously wrong these days, @thols. Writing style is like a fingerprint. I'd rather read something with a bit of dodgy grammar in it, some imperfect sentence structure, some spellers and typos, at least it feels like the voice of the writer, if that makes sense.
@cougar I always conflate labyrinth and maze. It's the Minotaur thing.
