is it easy to chang...
[Closed] is it easy to change a car stereo these days ?
The pioneer stereo in our mk 4 Golf is ok, but, dating from 2002, it has no aux in or usb.
Are the connectors likely to be standard so that I can just buy something at Halfords (or wherever) and relatively easily slot something newer in ?
The last time I fitted a car stereo was about 30 years ago and it was a right hassle, but at least I didn't have immobilisers/alarms to potentially ruin my day back then...
Thanks
Posted : 02/11/2013 8:51 am
As long as the old one has ISO connectors on the back - about 10mins start to annoying the neighbours.
If not you'll be swapping cables but should still only be 20mins
Posted : 02/11/2013 8:54 am
There used to be online compatibility checkers back in the day, try a google search and see what come up, they used to tell you what size blanking plate you'd need to fill the hole too.
Posted : 02/11/2013 8:55 am
It'll either be an iso connector or you can but an iso adapter on eBay for a few quid (or a fair bit more from halfords)
Thanks. I hoping to get one the same size (it's what I'd call 'old-sized') so no blanking plates with luck.
is exactly what I want.
Posted : 02/11/2013 8:58 am
Din or double din is what they used to call those sizes. Remember doing the one in the old scoob. Had what seemed like half the ****in dash out to get the old double din stereo out!!!!
Posted : 02/11/2013 9:17 am
Does your car have steering wheel controls for the stereo? If so you may need a lead so that you can use your new stereo (if steering wheel compatible)
http://www.connects2.co.uk/ProductRange.aspx
Posted : 02/11/2013 9:24 am
 P20
Should be straight forward. There will probably be walk through guides on the web. Buy the single din facia from VW and it should come with a adapter harness.
Posted : 02/11/2013 9:43 am
Do a quick search of the VW forums, you might get lucky and find an aux jack kit that just plugs into a spare socket on the back of the radio. Sometimes they can plug into the CD multichanger socket.
Posted : 02/11/2013 9:48 am
 pdw
Mk4 golf is DIN so that part is easy. If I remember right, the connectors are ISO but have the battery and ignition lines swapped over. You may also need to get an antenna amplifier.
Posted : 02/11/2013 10:05 am
Take the old one out and have a look. You may need a special tool to get it out, eg u shaped wires which disconnect the security lock, those come with the sterio but are probably long gone.
Posted : 02/11/2013 10:56 am
pdw - Member
pretty sure that this is correct from memory of my old Golf.
P.S. Not sure a 2002 mk4 Golf counts as "these days" ๐Ÿ˜‰
Posted : 02/11/2013 10:59 am
