Internet usage ques...
[Closed] Internet usage question
Do you leave your laptop on all the time? If not, then when you turn it on, take 10secs to turn your router on at the same time.
Well yes, our iPhones are on all the time and connected to the wi-fi.
Granted the netbook does take around ten seconds to start, but it's downstairs, next to the couch, as is the Wii, whereas the router is upstairs in the study (so it can be wired to the main desktop and the printer).
Not a major hassle, but running upstairs whenever I want to browse the web would kind of remove the convenience factor.
Also I suspect if you keep turning off the modem then it might screw up the speed negotiation. I'm sitting at a solid 8Mbps and I'd like to stay that way.
Ah, unless you can't access your router as it's actually in your neighbours house!?
My neighbour is in his 80s. I'm pretty sure he doesn't know what an internet is.
I can sometimes see the pub's wi-fi from the house, when the wind is blowing the right way, but I'm happy enough to use my own connection.
(Though I have absolutely no qualms about using whatever open wi-fi I find when I'm out and about).
Posted : 09/12/2009 2:18 pm
Furry Muff.
I feel somewhat in the dark ages now, what with having a laptop & a desktop rather than an iphone and a netbook that are permanently ready to go.
I can see how having it on all the time would be more convenient in the situation you describe above.
(fair enough, in case you were wondering....)
Posted : 09/12/2009 2:49 pm
WPA is pretty easy to crack when you have a non-slim PS3 lying around.
Nothing is sacred.
Posted : 09/12/2009 3:03 pm
Details Dougal?
Posted : 09/12/2009 3:19 pm
MuddyDwarf - if you are still having problems, it would be good for you to post up the following:
Model of your router
No. and types of devices connected to it
What anti-virus software you are using
What firewall you are using
Knowing these will take some of the guess-work out of helping you.
Posted : 09/12/2009 3:27 pm
OK.
Router - BT home hub 2
Devices - one laptop
Anti-virus software - AVG free (can't afford to pay)
Firewall - windows and AVG
I have a total broadband download to monitor the usage from the laptop. Unfortunately we reset-to-default the router yesterday before altering all the passwords so any data stored about any other devices logging on has been deleted.
How do i alter the MAC address?
Posted : 09/12/2009 4:32 pm
Also, the BT home hub router doesn't flash when in use so i can't tell whether or not someone is using it.
Currently unplugging the router from the phoneline when not in use, think i'm going to revert back to a hardwire connection for a week or so as well.
Posted : 09/12/2009 4:36 pm
Just found this quote about your hub....
By the way, you haven't enabled FON have you? In that case you will get others using your hub legally because you have given them permission by using FON.
Have you enabled FON?
[url= http://www.filesaveas.com/btfon.html ]Info on FON[/url]
Page 2 / 2
