Interchangeable/hot...
[Closed] Interchangeable/hot swappable jack plugs
Does anyone know if there is anything like an interchangable modular audio jack plug that can be fitted to headphones?
I have a set of studio headphones for home audio production stuff - sometimes I'm working on my laptop, without an audio interface, and I need to use a 3.5mm adaptor on the 1/4" plug. Other times, I can be in a studio or using a mixing desk etc and they plug straight in.
The problem is that the 1/4" connection is loose, and compounded by using the 3.5mm adaptor it can be pretty crackly and unpleasant.
I'm going to replace the plug, but before I do I wondered if anyone knows of anything where you can change the tips of the jack between 3.5mm and 1/4 on the same connector?
Posted : 04/03/2019 1:31 pm
As in a 3rd "standard" plug which would then need adapters for 1/4" and 3.5mm?
That sounds a lot more work than 5 minutes* spent soldering on a new 1/4 jack.
*includes pontificating over which soldering tip to use, the ethics of using lead solder rather than the green stuff** and making a cup of tea.
**the green stuff cracks meaning stuff gets thrown away, thus bad for the environment.
Posted : 04/03/2019 1:50 pm
I used to use Sony Studio monitors where the adapter would screw on to the smaller jack. No crackles.
Posted : 04/03/2019 1:52 pm
screw on adaptor on my Sennheiser HD25's as well.
Are they really 'studio' pro quality? If they are there may well be alternative leads you can buy. I know my Sennheisers came with a super tough thick straight cable but you can also buy coiled cables and thinner/lighter ones for mobile use.
Posted : 04/03/2019 2:00 pm
They're a set of old but good Pioneers, with a non-detachable cable.
As in a 3rd โ€œstandardโ€ plug which would then need adapters for 1/4โ€ณ and 3.5mm?
No, just wondered if anyone made a plug housing that you could change the tips on. Using adaptors is always a bodge.
Thanks, will take a look to see if I can find something like that.
Posted : 04/03/2019 2:40 pm
Seems easy to find the adaptors, just not the plugs
https://www.studiospares.com/Cables-Leads/Adaptors/Screw-In-Mini-Jack-Socket--Stereo-Jack-Adaptor_448768.htm
Posted : 04/03/2019 2:53 pm
