Land Rover defender 110, limited slip diffs, studded tyres, snow chains.
I laugh at the rif raf in their Chelsea tractors sliding about in the snow.
Went to Countrywide the other day to fill up with LPG at 58ppl on account. Pump out of order.
Went to FloGas depot yesterday to fill up at 68ppl. Guy warned me they are nearly out and are prioritising cylinders over autogas, so may be out for a while.
Either a long drive to refill elsewhere, if they haven't run out as well, or petrol at 120+ppl. ๐
dont worry - you can fill up with 120ppl petrol this once then return to being smug for the rest of the year with your 58ppl LPG.
Don't put yourself down, the first 1/2 of your post is still pretty smug so don't be too disappointed with yourself if thats possible.
[i]studded tyres, snow chains.[/i]
I suspect you wear a belt and braces too.
You think that's smug ?
You should see me waving the tow rope out the window as I drive straight past. ๐
nevermind eh
Whats the mpg like with gas compared to petrol?
Studded tyres? Illegal in the UK?
I'm getting about 4.5 km per litre.
Pretty dismal, even for a 3.9 in a 110.
That's around 20p per mile on fuel alone.
Maintenance costs are pretty low and depreciation is virtually nil though, so I don't know how the overall running costs compare with a normal car.
First I've heard of that. Link ?
wwaswas, the studs are in permanently, or until I change the tyres again and don't affect normal driving much.
The chains are for emergencies only.
Damage to road, person or vehicleIf the tyre causes either damage to the road, or to persons, or to any vehicle using the road. This would cover such instances as if a vehicle with damaged or very oversized tyres which either caught against a person or other vehicle resulting in either damage or injury. Studded tyres also are included in this clause and if used in inappropriate conditions (i.e. where there is no ice or snow) and they damage the road surface then they would be clearly illegal.
From http://www.etyres.co.uk/uk-tyre-law
wot woody cut'n'pasted - as soon as you use studded tyres directly on tarmac you're in danger of getting a ticket.
Shell garage in Semly pl sw1 has got some, you can leave the snow chains off......... sarcasm not quite matching smugness!
I think "inappropriate conditions" is the key phrase here.
I only put them on a few days ago and I'll take them off again as soon as I can to save wear.
They will just about mark smooth concrete. They make no visible marks on tarmac.
I've seen a lot of steel wheeled traction engines leaving scuff marks on the road without getting a ticket.
[i]I've seen a lot of steel wheeled traction engines leaving scuff marks on the road without getting a ticket. [/i]
You may find that as these were original equipment they're allowed.
Tracked vehicles aren't allowed ont eh highway unless they have rubber blocks on their tracks for this reason though.
The rules for tracked vehicles are a little more complex than that.
I'm sure the words "resilient material" come in to it somewhere.
All metal tracks on all metal wheels, yer typical bulldozer for example, are a definite no no.
I think, but I'm not sure, that you can get away with all metal tracks as long as there is a resilient material material between the track and wheels. Usually this will take the form of a rubber tyre on each wheel.
The rules about damaging the road surface still apply though, so most people using a tank on the road will fit "hush puppy" type tracks, the ones with rubber pads on their surface.
Go to any steam rally and for several days afterwards you will be able to see which way the steam rollers went home.
Have a look where I have driven my Land Rover and there's no trace.
So - would it be cheaper to run it on petrol?
[i]Have a look where I have driven my Land Rover and there's no trace. [/i]
a stealth Land Rover.
I've never run it long enough on petrol to get a meaningful consumption figure.
10% worse on LPG is a rough guide though , so with LPG at less than 50% of the cost of petrol, no.
Where I park it is a different matter of course.
One puddle under the engine, one under the gearbox, and one under each axle.
As all LR owners know, if there's no fresh oil stain under it then there's no oil in it ๐
I'm more interested where you got the Limited Slip Diffs from. Bit of a rarity on a LR.
We're loving this weather: http://www.bbc.co.uk/news/business-12049292
Shame the Beeboid can't leave out the usual crap about AGW in what should be a good news story about a major british manufacturer and exporter.
I like to wave my comfortable, air conditioned, nicely music listened, not deaf, 600 miles a tank, oil retaining arse out of the window as i pass landrovers on the roads of britain on the 363 (average) days a year they are perfectly passable to a normal car. ๐
woody2000 - MemberDamage to road, person or vehicle
If the tyre causes either damage to the road, or to persons, ...
So that provides for a new thread. "What tyre for legally running over people"
The mind boggles ๐
My mate competes in 4x4 off-road trials and his weapon of choice is a V8 Landy.
His road car is a Shogun. Its only a matter of time before the Landy breaks down and you're towed home by something Japanese. Gotta love that V8 sound though! The throttle doesn't always stick. ๐
psling, it's these.
http://www.eaton.com/EatonCom/ProductsServices/PerformanceProducts/Products/Differentials/DetroitTruetrac/
i remember seeing that old 90 from the fast show in a council estate just off the stratford road in birmingham when i was trying to find a shortcut.
Saw lpg at 79p in a garage in wakefield yesterday, seemed expensive as we havent had snow for weeks.
You have no idea what you are missing. ๐
Didn't know Landrovers came with Limited Slip diffs? That's a new one on me after owning six of them?!
Replied in the wrong thread...
goldenwonder, MTQG's link above ^^ would suggest his LSD's are aftermarket.
Fair enough, serves me right for not reading the thread properly!
Just had a quick look, similar to the Quaife ATB's then? Very nice, didn't know such a things existed for a LR.
School day for me then.
having been carted around on and off road in all weathers since i was a baby in every kind of landrover short of a forward control I know exactly what i'm missing.
For the last 3 years the only vehicle able to get to my parents house for at least 2 weeks of the year has been a landy so i'm fully aware of the need for them. It's just that after the half mile track i far prefer to get into my car ๐
