Ikea integrated was...
[Closed] Ikea integrated washing machines
[#3192001]
I need to replace our washing machine, house came with a standard Ikea kitchen, will any integrated unit fit? Or dies it have to be ikea only?
Posted : 28/09/2011 11:53 am
All intergrated appliances are approx the same size as a rule. Door hinge positions may vary to what are currently routed oot on the back side of the door. If so you can either get a new door or buy a hinge cutter.
Posted : 28/09/2011 12:10 pm
Cheers, first time I've had integrated, simpler than headsets then! Thanks.
Posted : 28/09/2011 12:12 pm
Stop!! Would be worth dragging out tho and checking, this is after all the world of stw. But in all honesty it's usually set behind a standard 600 base unit. The only issue I had when I put my new one in was it wasn't as tall so I built a little plinth for it to stand on! Also allow a good £100/£150 extra just for the fact it's integrated! 🙄
Posted : 28/09/2011 12:18 pm
Yeah, was going to measure it up jsut to be on the safe side, need to check the hinges etc. ta.
Posted : 28/09/2011 1:52 pm
