and if you are at the 25th percentile, are you part of the lower quartile group?
only on weekends
No to the first question, yes to the second
see, that's what I thought.
Q1 = 0-25%
Q2 = 26-50%
Q3 = 51-75%
Q4 = 76-100%
This could be a painful message to give (and to receive) for the person at number 25...
not as bad as decimating them i hope
Q1 = 0-25%
Q2 = 26-50%
Q3 = 51-75%
Q4 = 76-100%
You've got 101 points on your scale. If its only discrete numbers it should be
Q1 = 1-25. Otherwise your first quartile is 1 larger than the others.
If its non discrete (i.e not only whole numbers) you're not allowing for the values between 25% and 26%, 50% and 51% or 75% and 76%.
Colin
thanks Colin, it's discrete. I'm only concerned with those individuals at the quartile boundaries and haven't been explicit about the ranges that have been used, but I see your point on the 0th percentile so will change it to 1st if I need to.
