If there is no oxyg...
[Closed] If there is no oxygen in space....
then how come the sun is on fire?
Posted : 13/07/2013 10:04 pm
It isn't.
Posted : 13/07/2013 10:08 pm
its not on fire
it's not on fire.
(edit - looks like others beat me to it)
And how cme we can breathe on earth which is also in space??
And how come rockets work in space when there's nothing for them to push against?
Posted : 13/07/2013 10:10 pm
And nothing for them to fly through
Posted : 13/07/2013 10:12 pm
if only you had paid attention during science lessons...
How come Planet X is a bike company and not an alien porn channel?
'They Came [s]From[/s] In Outer Space'.........
Posted : 13/07/2013 10:14 pm
Spaceships and conveyor belts.....
Posted : 13/07/2013 10:15 pm
Every action has an equal and opposite reaction.
You asked a dumb question and you got a dumb answer.
HTH. ๐Ÿ˜‰
Posted : 13/07/2013 10:16 pm
[i]if only you had paid attention during science lessons... [/i]
We did. And we paid attention in irony lessons too. ๐Ÿ˜‰
And how come we can breathe on earth which is also in space??
Atmosphere...I'll let Russ Abbot explain it.
Posted : 13/07/2013 10:18 pm
ironing? that was home economics surely...
Here's the thing. If part of the sun was on fire, would the rest of the sun be hot enough (or whatever it needs to be) to produce enough oxygen to allow that fire to burn?
Posted : 13/07/2013 10:19 pm
Ironing was metalwork.
Oxygen was music class
Posted : 13/07/2013 10:23 pm
About 0.9% of the sun is oxygen, and it's the third most common element in the universe
Posted : 13/07/2013 10:28 pm
So... my question remains.... howz it do it???
Posted : 13/07/2013 10:35 pm
If you're being serious, it's not on fire, it's a nuclear reaction.
Posted : 13/07/2013 10:36 pm
[url= http://lmgtfy.com/?q=how+does+the+sunwork ]let me google that for you[/url]
Posted : 13/07/2013 10:39 pm
Yep. Just like an H bomb ( the big ones not Hiroshima) but it's millions of times the mass of the earth and has been continually exploding for billions of years instead of a split second.
Posted : 13/07/2013 10:40 pm
Well I never more common than Carbon, but only just
The sun works by converting Hydrogen to Helium, oxygen not needed
Posted : 13/07/2013 10:42 pm
rockets move not by "burning" but by expelling part of their mass at high velocity in the form of fuel. best way to do this at high velocity (with current technology) is to burn it; half of the fuel load is liquid oxygen, so that explains where that comes from. Other propulsion systems may be available...
if you chuck some mass in one direction, you will move in the opposite direction. try it next time you go skating
Posted : 13/07/2013 10:53 pm
Duh, the sun burns cos of nuckeeur fissushion. To do this it needs Oxygen. It's soo big, bigger than anything in space. It uses all the Oxygen available in the rest of Space, that's why. You're so stewwpid.
Posted : 13/07/2013 11:08 pm
Posted : 13/07/2013 11:14 pm
[i]if you chuck some mass in one direction, you will move in the opposite direction. try it next time you go skating [/i]
I was fine skating when I had something to push against but when I tried it in a vacuum in zero gravity, I got nowhere.
(I know what the answer is, just like I suspect most people participating do to all the questions above), I'm just having a laugh.
Posted : 13/07/2013 11:26 pm
The Sun does not "burn", like we think of logs in a fire or paper burning. The Sun glows because it is a very big ball of gas,and a process called nuclear fusion is taking place in its core. Nuclear fusion occurs when one proton smashes into another proton so hard that they stick together...and release some energy as well. This energy then heats up the other materials (other protons and electrons and such) nearby. This heating eventually grows out from the center (or core) of the star to the outside, finally leaving the surface and radiating out into space to be the heat and light we know stars emit.
People, including scientists, sometimes say that the Sun "burns hydrogen" to make it glow. But that is just a figure of speech. Hydrogen really doesn't burn, it fuses, into helium. So no oxygen is required!
Now I can sleep. Nite all. X
Posted : 13/07/2013 11:32 pm
Who let this happen???
WTF guys were you all asleep? Slowpokes, sheesh.
Posted : 13/07/2013 11:38 pm
Posted : 13/07/2013 11:40 pm
What happens if the protons aren't a very good aim and all miss each other? Does the sun go out?
Posted : 13/07/2013 11:42 pm
The sun is really, really heavy. You try escaping from it.
Posted : 13/07/2013 11:48 pm
heavy like one of those big heavy bowling balls when you go bowling. the one you pick up and break yer fingers. That kind of heavy? Like, proper heavy?? so you go for the manageable purple one, that's like Earth, compared to the heavy one's Sun. I get it now, Space is like bowling. I bet they use this analogy next time Kate Humble fronts a sciency spacey programme!
Posted : 14/07/2013 12:16 am
 JoeG
Pink Floyd directs solar operations. Instructions given at 1:54.
Posted : 14/07/2013 5:05 am
In Space, you can Hunt for Red October.*
Or something.
http://www.theregister.co.uk/2013/06/28/nasa_to_shut_down_long_running_next_ion_propulsion_test/
That ionized plasma is created in an area of the engine with a highly positive charge, and the ions are thus attracted to the highly negative charge of the engine's "accelerator grid," which spits them out into space โ€“ or, in NEXT's case, the test chamber โ€“ at speeds of up to 90,000 mph.
* laboured caterpillar drive reference....
Posted : 14/07/2013 9:21 am
There's no such thing as a dumb question. Just dumb people.
Posted : 14/07/2013 9:30 am
Sun (yellow dwarf star) is undergoing a fusion reaction where Hydrogen is converted to Helium.
This reaction releases a lot of heat and light (E.M.) energy.
The Earth has gravity which stops some of the gas escaping into space.
Source: My year 7 plenary in their own words (bottom group science)
Posted : 14/07/2013 9:42 am
Fancy making them come in on a Saturday.
Posted : 14/07/2013 9:45 am
I would but that's my day to ride!
Now marking...hoping to ride midday...
O.P. google "fusion reactor" where scientists are trying to build a fusion reactor that gives off more energy than we put in to stabilise it. (To heat water and turn the turbines and mega watts of electrickery! ๐Ÿ˜‰
Posted : 14/07/2013 9:49 am
There IS oxygen in space.
(It's just spread around quite thinly, so getting a decent breath becomes tricky.........)
Posted : 14/07/2013 11:29 am
How does a graviton get out of a black hole?
Posted : 14/07/2013 11:41 am
Who's there?
Oops, sorry, wrong punchline
Posted : 14/07/2013 11:43 am
And it is because of all this helium that the sun floats up in the sky the way it does.
Posted : 14/07/2013 12:00 pm
Bowling balls probably have more weight in USA as they are closer to the equator. so, as this is a UK based forum, I'll agree (on principle) my theory, though not wrong, can be manipulated. So, I'm ooot.
Posted : 14/07/2013 1:02 pm
from wiki-bloody-pedia:
...At the center of the Sun, theoretical models estimate it to be approximately 276.5 watts/m3,[54] a power production density that more nearly approximates reptile metabolism than a thermonuclear bomb...
which means; your body is more powerful (per unit volume) than the sun, which i think is amazing.
Posted : 14/07/2013 1:14 pm
ehhm.. now that's interesting!
Posted : 14/07/2013 1:31 pm
Actually, no. Given the equatorial bulge and centripetal acceleration, the effective resultant gravitational force is lower at the equator than at the poles. Hence Americans are lightweights.
Posted : 14/07/2013 1:37 pm
There must be oxygen in space, else how would the Death Star/tie fighters/x wings have blown up in big fire balls?
Posted : 14/07/2013 4:16 pm
they carry their own oxygen, silly. how else would the pilots breathe?
Posted : 14/07/2013 4:32 pm
Darth Vader has that fancy suit that goes "psssssh-ksssh" a lot.
Posted : 14/07/2013 6:59 pm
My body's not that of a reptile - just saying.
Posted : 14/07/2013 8:19 pm
ononeorange - Member
Protesting too much there, lizard-boy.
Posted : 14/07/2013 8:21 pm
