Sampling rate? (Lol)
quite small though houns...
Another red wine, sir?
I was running round the track....
you're only cheating yourself..... ๐
Which HTC?
slainte โ rob
Desire S
iDave - Member
Desire S
Not sure about the S, but my Desire HD has always given iffy results (in contrast to the HTC Hero I had previously which was pretty accurate for a phone). Did some interwebs digging and seem to be a few Desires that don't have great GPS accuracy, so that issue might have carried over into the S?
In the end bought a PAYG Pulse Micro from T Mobile for 20 quid to use as on the bike GPS. Seems to be as accurate as my Hero was and I don't have to worry about damaging the Desire. Only issue is that I have to wait until home to upload via wireless as I run it SIMless for GPS.
Also, I personally found Endomondo to be slightly less consistent tracking-wise than SportyPal which I now use.
Could also try Tracker Booster from the Market to see if that helps (didn't do much for me, but other users report decent improvements).
slainte โก rob
Plus the heights are completely off the scale. I did a 125 miler a few weeks back around Calderdale and my local hills. The total height claim from my HTC/Endomondo was 1200m whereas when I dropped the GPS file into Memory map, the height claim was a far more believable 3100m.
Why do you need a GPS if you are running around a track? Just thought you would keep turning left and you would get back to the start point.
Feet and metres can be very, very confusing for me too. ๐
hig, i wanted to measure how slowly I run, and what the altitude gain is on a running track - which was quite considerable.
jamie - 600m? call that a run? pfff.
my desire s always surprises me with just how accurate it actually is even under trees. I use everytrail though as I didn't like endomondo.
[i]Feet and metres can be very, very confusing for me too.[/i]
Not with you mate, sorry.
Suppose you could use a calandar for the timing! ๐
But for the height gain, thought it would even out if you are doing complete circuits, unless it is a special upwards spiral running track
Hurdles made it feel longer ๐
I think it needs a clear and uninteruppted view of the sky, which is nearly impossible.
I use Endo for running and biking, and it seems very erratic. I think its the GPS in the phone though, not the app itself.
I left mine on accidentally after a cycle roungd the Trossachs a few weeks ago, and the most accurate part of the journey was the car ride home! Followed all the roads spot on..... most frustrating! ๐
Neil F - Member
Check your phone/app settings.
IIRC some have a 'snap to roads' feature.
slainte ๐ rob
I tried endomondo once & it was rubbish. I tried it out at Rutland water & there were multiple places where it had a clear view of the sky but completely lost gps tracking.
My Tracks on the other hand is pretty much spot on - even in thick tree cover it works stuck in the pocket of my rucsack.
When I'm on the road it's accurate enough to trace what sire of the road you are on.
That's on a Desire.
I have the Desire HD. Got it as a free upgrade, and frequently get lost trying to use it. Maybe I am getting old!
How do I go about doing any of the above? And what kind of useful mountain bike things can I do with it?
My Tracks app on Desire (not S or HD) is usually spot on for me.
I'm pretty sure the altitude numbers it comes up with are complete nonsense though
I run Endomondo on a Blackberry, my BF has it on a HTC Desire. There was always a significant difference in stats, and when compared to a Garmin it was the HTC that was wrong.
The tracking on the HTC got steadily worse (tracking into the North Sea, giving max speed of 700mph etc) until my BF took it back... they had the phone a couple of weeks, admitted it was faulty and sent out a new (recon) one. Endomondo on the replacement Desire now gives a good track and similar stats to my BB/garmin.
Agree the altitude stats on either phone don't seem great.
113ft altitude change on a running track!
It seems to be fine cycling. Maybe it doesn't like the jiggling around when I run, what with me keeping it in my bra...
Mixed results with my tracks on desire s. Did a roadie ride and it mapped my u turn in front of the house and riding into drive. Did a motorbike ride and it put me in fields next to the A44. My line through the glorious Fish Hill sweepers might not have been perfect but it wasn't that bad ๐
Its a pity these phones arent WAAS enabled.
I'm using my tracks on my HTC sensation and if anything its very accurate but for proper accurate tracks you would be better of with a stand alone TLS device
Where does the OP carry the phone?
on the end of a 35ft carbon antenna, attached to my bra
Well clearly not. How? Armband type affair?
back pocket of shorts... tight fitting shorts too....
Use maths for that one? or a clock... more time is slower than less time iirc.
Theodolite but I would just go for zero personally
I haven't read any of the thread after LOLing at Houn's track.
8)
right, firstly....proper lol at houns.
next...how would I go about doing as you guys have done and be able to plot distances etc on a map like the above.
please forgive me as i'm useless at techno stuff....i still record cd's onto the pc and then transfer to my phone if i want music on my phone..never bothered learning how to do that either ๐ณ
Use a GPS device - and a programme to load stuff into it
say a garmin ETREX, Edge whatever and Memory map - lots of other programmes/GPS or phones available
Get an app for a phone - no idea on which but threads galore on this issue
transporter13 - as I mentioned I use the My Tracks app on my phone but there are loads that do the same thing
It depends exactly what you want to do - if its just to work out some distances you can just draw the route onto a map using [url= http://www.mapmyrun.com/routes/create/ ]http://www.mapmyrun.com/routes/create/[/url] (other sites are available)
