Cold turkey might be my only way out...
I actually put in a formal request for that at the place before last. They were really confused. Ultimately they just ignored me.
awww - but we would miss you!!!! xxx
Rachel
I'd still be here in the evenings.
Having considered this there is a risk that my web use might be subject to scrutiny leading to a P45 🙁
Unfortunately I work from home most of the time on my own connection so there is no limit to the amount of time I can waste on here.
Are you accessing through a VPN though? If so they can and probably are logging your web use, though it's unlikely to be looked at unless you piss someone off.
Use Leechblock (firefox add-on). I had to resort to this 🙁 Restricts access to certain sites during a set of core hours of my choosing...
Use VPN but that's in a VMWare session, so my STW activities are not being logged.
To be honest how often I see some of you on here join the day I did wonder if you had jobs 🙂
I changed my router to only allow me access to stw at certain times of the day.
Then I cheated and reset it.
I've got it bad.
Mrblobby, setup remove administration on your router and give me the details, I'll set it so you cant view stw and I'll change the router password ;). Problem solved!
I banned it on our firewall at work.
after about 10mins I put an exception on my IP address.
How do you know who's on here unless you are?
Because i'm off sick at the moment else I wouldn't be on here join the day.
There used to be a list at the back of ST mag for the highest user on STW. One year it was gingerflash.
You'd definitely win TSY.
Definitely is a bit of a strong word!
I had to get the orange 18 restriction lifted from my dongle to access - now IT think I access porn at work 🙄
EDIT; gineger flash nearly lost his job when he was caught IIRC and no longer posts - not seen Mrs Flash for a while either
I work from home for a US company in sales. I log onto my PC in the US for my work stuff, access here on my home PC so I'm prety sure that unless they come over thye can't see what sites I'm on. And my sales are OK so they have no reason to check up on me. I do only log on here if it's quiet 😆
Someone's going to tell me they can see this mow aren't they 😳
