I can't descri...
[Closed] I can't describe it to get a Google hit. Battery adapter thing????
What I am after is a female plug socket, the type that would match a male mains adaptor that can be plugged into battery or mains appliances. One that has a the two wires already attached as tail leads.
The one with the +ve and -ve on the same plug, concentric and then into a socket with a pin in the middle.
About 4mm diameter but lots of standard sizes available.
It's for a hot wheel conversion to save shelling out pounds on D batteries.
I cannot think what they might be called or even get anywhere near on google.
Posted : 28/07/2016 8:09 pm
Try searching for 'DC Power Connector' plugs and sockets - searching maplin maybe to find something to suit
Posted : 28/07/2016 8:17 pm
If it's a standard mod, maybe google for a guide as they may mention the part?
Posted : 28/07/2016 8:18 pm
It might be standard, but we are thinking of overvolting the hot wheels booster to get extra oomphage.
Posted : 28/07/2016 8:26 pm
DC Power connector...bingo. thanks Mac.
Top 4 items:
http://www.maplin.co.uk/c/cables-and-connectors/connectors/dc-power-connectors
It seems the socket on the equipment to be powered is actually considered Male. If you are searching for female you will find the plug.
https://en.wikipedia.org/wiki/Coaxial_power_connector#Male_.28receptacle.29
As a wise man once said, the light that burns twice as bright burns half as long. Try not to kill it in the process.
Posted : 28/07/2016 8:41 pm
Yeah just a straightforward dc power connector. You'll pick up 2.1mm male/female with screw holes for trailing leads pretty easily if you look under cctv equipment.
Posted : 28/07/2016 8:44 pm
Didn't every home have at least one of these in it back in the 80s?
[i]Universal[/i] DC power supply, for Google purposes. Don't forget to get the polarity right.
Posted : 28/07/2016 8:45 pm
Looking at the images against female, it looks like a female I need, the part that would be in the device?
Posted : 28/07/2016 8:46 pm
Cougar, mine has a selection of ends rather than the throwin star arrangement. So I need the other bit, it goes into, with two wires coming off.
EDIT...going to 5volts over the stock 3v supply, so not a massive upgrade and I'll add cooling, maybe.
Posted : 28/07/2016 8:49 pm
3 to 5v...whistles! May only be 2v increase, but its also something like a 60% increase.
Posted : 28/07/2016 9:57 pm
Buy a fire extinguisher.
Male rather than female, then.
Posted : 28/07/2016 10:01 pm
