I can wheelie but c...
[Closed] I can wheelie but crikey I can't do a manual....why are they soooooo hard?
[#2393639]
Just can not get the nack of this cool move......
essential on the trials of course...... 😯
Posted : 22/01/2011 11:06 pm
they are hard cause you do not practice enough, simple.
Posted : 22/01/2011 11:08 pm
hmmm,
They are tough, the only tip I can give is to try them going down a hill? I think it makes them easier to pop up and hold.
Posted : 22/01/2011 11:18 pm
tried that but still no joy.....It's the feeling of the bike rolling out from under me i can't get used to
Posted : 22/01/2011 11:43 pm
 AJ
you know what practice makes? Afraid that's the only way to nail this. I think even Jedi doesn't have a mind trick for this one.
Posted : 22/01/2011 11:45 pm
could try one of these! :-
Posted : 22/01/2011 11:48 pm
Well I can wheelie since a kid. But not to the standard of coastkid etc. But ok - ish. Manualing took a lot longer. I'm still far from getting it mastered, but the key things so far on my journey are:
0: Look ahead (plan the move and what comes next).
1: Its not about hands / arms / pulling.
2: Preweight the front and move back.
3: Heels down!
4: Learn how to skim your ass over the saddle (just) as it passes toward the rear wheel.
5: Push your feet forward toward the front axle (THIS IS THE CRUCIAL BIT).
6: Maybe a wee twist on the bars with both wrists as you get as far back. Keep the bars straight.
7: Cover the back brake with a finger. When it does work it can be really scary!
8: Practice.
9: Again and again.
10: Repeat 9.
Even I can manual (or I could at one point a while ago when I last tried), and I'm an XC Jeyboy. It does take practice, though with the right instruction surprisingly little. I picked up the knack whilst on holiday when the bike guide offered a "wheely and bunnyhop" clinic - given I was the only taker (it was a sailing holiday with a bit of biking, so not many into it) I got one-on-one tuition and largely picked it up in an hour. Not sure if I could still manage a bunnyhop without being clipped in though.
Posted : 22/01/2011 11:51 pm
is it easier on a slight downhill gradient? or a steep ish slope. Steeper seems to give the feeling that the back wheel is going to overtake the front.
Posted : 22/01/2011 11:52 pm
Rockhopper - I'd say you're nearly there. That's the feeling you want - but just under control! A slight down slope helps a lot. When you get used to it you can do one in post places, except climbing.
Posted : 22/01/2011 11:58 pm
Just to add: here is a chap on a fixie who does a manual, then a bunny, to avoid a crash, in a race, with no warning etc. He just jumps over the rider who crashes in front of him. Its just subtle movements over the saddle, and pushes with his heels. I dont know how to show this in slow motion but here it is (at 18 secs in):
Posted : 23/01/2011 12:17 am
Chriss Akrigg isn't it. He is OK on a bike I suppose and he does get to pracrice a lot I understand.
Posted : 23/01/2011 12:23 am
thats barely a manual, more a quick front and rear hop. pretty sure he used the guy as a ramp too
Posted : 23/01/2011 3:10 am
Rockhopper:
do you struggle getting it up? or holding it there?
what bike are you trying it on?
(some bikes are easier/harder than others)
Posted : 23/01/2011 9:06 am
Isn't a fixie the only bike it is actually impossible to manual, what with the fixed thing and all that?
No footed I suppose...
Posted : 23/01/2011 9:23 am
Some of the bikes people use round our way would hinder any man in getting it up!! 😉
Posted : 23/01/2011 10:24 am
all you need's a little time:
http://video.mpora.com/watch/jBwiMsFTb/
Posted : 23/01/2011 10:37 am
Rockhopper:
Posted : 25/01/2011 9:09 pm
a full suspension xc.
i guessed as much.
a well designed, correctly sized xc bike will do a good job of resisting wheelies - to keep the front wheel under control on steep climbs.
it should have a longish top tube and or stem, which positions your weight well in front of the wheelie balance point.
it can be quite tricky to overcome this, not impossible, but tricky. especially so if you're not really sure what you're doing anyway.
chances are, you've got the technique more-or-less right, borrow a bmx and give it a go on something much, much easier.
Posted : 25/01/2011 9:33 pm
