Community
How to find a slow ...
[Closed] How to find a slow puncture in sleeping mat
I have an Alpkit self-inflating sleeping mat. It goes down after a few hours sleep. I have blown it up and put it through a bath but couldn't spot a leak. Any other suggestions how to find it or if it is >5 years old should I maybe accept it is a goner and leaking through the fabric?
Posted : 17/07/2017 10:00 pm
 km79
Maybe?
Posted : 17/07/2017 10:05 pm
Dunk it in a bath of water
Posted : 17/07/2017 10:13 pm
Yep in the bath. You're not looking hard enough ๐Ÿ˜‰
Posted : 17/07/2017 10:17 pm
1) Bath.
2) get onto Alpkit.
3) What model is it?
Posted : 17/07/2017 10:22 pm
Strong fairly liquid/water mix in a squirty bottle.
[url= https://s14.postimg.org/eukidwktt/tumblr_mmrss9_VMVj1s6aepxo1_250.gi f" target="_blank">https://s14.postimg.org/eukidwktt/tumblr_mmrss9_VMVj1s6aepxo1_250.gi f"/> [/img][/url]
Posted : 17/07/2017 10:29 pm
Washing up liquid and water in a spray bottle, inflate mat and spray all over you should see bubbles appear where the hole is.
Posted : 17/07/2017 10:31 pm
Ha, if only it was as easy as Stans! But I'm pretty sure that would not go far in the foam.
As above I already tried the bath fairly carefully but this squirty bottle washing up liquid sounds like a plan.
It's an old thick Alpkit one. Discontinued some while ago.
Posted : 17/07/2017 10:58 pm
..... do it more carefullier... It is a faff wrestling the b'stard but it has to be done ๐Ÿ˜‰
Posted : 17/07/2017 11:01 pm
That's why I asked. Fat Airic? It'll be the seam between the two sides.
Posted : 17/07/2017 11:10 pm
As above, strong fairy liquid/water mix in a spray bottle. Pump the mattress up hard, in the garden, and spray liberally. It'll be obvious where the hole is.
We had this in a double-height double bed mattress, no chance of getting it in the bath! Spray method worked a treat, but the hole was by a seam so couldn't really be patched. Fixed it by squeezing a little bit of silicone sealant into the hole, and then forming a patch of silicone over the outside. Worked a treat.
Posted : 17/07/2017 11:38 pm
Seams and valve joints are first places to check with spray if it's too big to submerge.
Posted : 18/07/2017 12:04 am
Alpkit had issues with the early Airics and replaced FOC IIRC...HTH TTFN
Posted : 18/07/2017 7:30 am
i have the exact problem so will be trying these tips. probably close to a 10 year old mat for me.
Posted : 18/07/2017 7:51 am
If it's the seam, it can be resealed with a warm iron. Go steady and work the temp up or you'll end up with a bigger leak...
Posted : 18/07/2017 8:08 am
Thanks Cougar! I couldn't remember the name but yes, Fat Airic, that is it!
OK it sounds like I should try the iron on the seams approach. I assume Alpkit would no longer replace.
Posted : 18/07/2017 9:22 am
fill it with water ๐Ÿ™‚
Posted : 18/07/2017 9:36 am
They didn't offer to replace mine, I chucked it in the end and bought a Thermarest.
Posted : 18/07/2017 9:38 am
Yergonnaneedoneoftheseandoneoftheseandsomefairyliquid.
Posted : 18/07/2017 9:41 am
