how the hell do I g...
[Closed] how the hell do I get this plug off?
 Pook
I need to thread the wire through a tiny hole but can't get the plug off as it all seems sealed.
Posted : 11/07/2014 8:02 pm
Yep. Think you'll have to cut it off and start again with the wires.
You'll need a new plug though...
Posted : 11/07/2014 8:04 pm
It is, snips.
You don't. It's a moulded plug.
Only way is to cut it off and put a new plug on or open up the device and remove it from the other end.
Or make the hole bigger.
edit: beaten by 7 seconds.
 br
Make the hole bigger or cut off the plug and re-wire it.
FFS Darwin is waiting for you! ๐Ÿ‘ฟ
Posted : 11/07/2014 8:05 pm
Snips and fit a new plug. Or go totally mental and dismantle and disconnect from the appliance end?
RM.
If you don't want to mess with the plug you could make up a small single extension lead with removable plug and pass that through the hole. If you do then (I am guessing that is a washing machine) you should make sure the plug is fixed high up and not on the floor behind in case of leaks.
Posted : 11/07/2014 8:07 pm
Make sure it's not plugged and switched on when you cut it....
Posted : 11/07/2014 8:08 pm
If it's attached to something that is in warranty then as andyl says
Posted : 11/07/2014 8:10 pm
 Pook
Sorted. Managed to reroute through the back of some cabinets. Plug remains unsnipped though my knuckles now need attention...
Thanks folks.
Posted : 11/07/2014 8:42 pm
