How on earth do you...
[Closed] How on earth do you move a washing machine?
 Ewan
[#4054364]
So, when I brought my flat I got the lady to chuck the washing machine in. Now we're moving out into our new house we're faced with having to move said washing machine. I live in a second floor flat.
Answers on a post card..... can you take the bits of concrete out of them to make them lighter?
Posted : 10/06/2012 5:10 pm
MTFU?
Posted : 10/06/2012 5:11 pm
more people, sack truck.
I think it requires the strength of two people or one big strong one
Posted : 10/06/2012 5:12 pm
 iBaa
Two man lift, bend with your knees, not with your back....
[url= http://www.hss.com/g/70494/Light-Duty-Stair-Climber-130kg.html ]http://www.hss.com/g/70494/Light-Duty-Stair-Climber-130kg.html[/url]
you get some mates and shift it.
Carry it you wuss
Posted : 10/06/2012 5:13 pm
It's a fairly comfortable 2 man lift. The hardest part I find is getting it in and out of the tight space. Once free it's easy enough to lift.
Posted : 10/06/2012 5:22 pm
 Ewan
I was worried MTFUing would be the answer! I will endevor to grow a set.
Posted : 10/06/2012 5:24 pm
WTF!? Granted its best with two people, but They are movable on your own. Only thing I've been unable to move on my own was my wood burner 🙂
Posted : 10/06/2012 5:25 pm
Y00t of today 🙄
Posted : 10/06/2012 5:26 pm
Most have a set of rollers at the back, so you should be able to wheel it most of the way if you tilt it back a little. As for any stairs - two adults should manage it comfortably.
If you are going to put your hands under the frame, wear gloves (bike gloves would be good) in case you catch your hand on some sharp metal.
Posted : 10/06/2012 5:27 pm
And have a load of old towels to hand for when it starts dribbling all over the place as you tip it over.
You have three options:
1. Carry it.
2. Leave it.
3. Pay someone else to carry it.
They are all pretty simple, you just need to decide which one fits your needs.
Hope that helps.
Posted : 10/06/2012 5:29 pm
Buy another flat with a washing machine in.
Posted : 10/06/2012 5:31 pm
yep, been there, done that 🙂
As above , mates + (if available) a sack truck is the way forward IMO.
Still makes me wince to think of me and 1 mate manoeuvring ours down into our cellar... bruised a few knuckles on that one...
edit - almost forgot - before connecting to the pipework don't forget to check the rubber washers are still in the hose connectors, not 'lost in transit' or you'll need to
been there, done that as well 😉
as above, easily done with two people. but if it's been used, worth repeating the advice above - it's guaranteed to leak water out of it, more than likely quite a lot.
Posted : 10/06/2012 5:32 pm
Plus 1 on the gloves. We recently had a similar move from first floor flat to house. We had a sack truck and wrapped it in a sheet. My top tips would be to put it on the truck sideways so if you scratch the paint it won't be visible in it's new home and also to drain it using the plug at the bottom [b]before[/b] you put it in the van.
Both tips I learnt the hard way 🙄
Posted : 10/06/2012 5:35 pm
and/or lay the drain hose flat on the floor into a shallow tray for gravity to do it's stuff.
Posted : 10/06/2012 5:37 pm
 Ewan
To be fair I've not tried to lift it - I just remember my dad taking one apart when I was about 10 and noting the large blocks of concrete in it!
Sack cart looks like a good call - easier to lift that down 4 flights of stairs.
Posted : 10/06/2012 5:39 pm
 piha
You might need some of this........
Posted : 10/06/2012 5:40 pm
Yeah, they can be grumpy old buggers, probably best just telling her you love her....................
oh, not [b]that[/b] kind of washing machine 😉
Posted : 10/06/2012 5:47 pm
Check the manual before moving it to lock the moving parts down so you don't break them. All the washing machines I've bought in the past have had a manual locking device to undo before using it.
Posted : 10/06/2012 6:28 pm
 Keva
the last time I carried one up to a 2nd floor flat I was helped by a girl.
Posted : 10/06/2012 6:46 pm
Leave it there if its a few years old and buy a new one ?Save the hassle .is it the one you inherited?
Posted : 10/06/2012 6:54 pm
Shove a cork in the drain hose to stop water leaking out, when outside lie it flat on the floor and the water will drain out,
Ratchet strap it to a sack truck to go down the stairs,
Put it on the sack truck on its side, to stop scratches,
Close and lock the door,
tape the cable to the top, as a cable trailing is eay to fall over,
get a strong mate to help,
Posted : 10/06/2012 7:22 pm
Posted : 10/06/2012 7:24 pm
Get the PG Tips monkey in!
If they were left around, its best to put the transit bolts back in. they stop the concrete block wobbling around and potentially stressing hoses etc. I once knackered the sump hose like this.
Posted : 10/06/2012 8:58 pm
like this(skip to 0:54):
Posted : 10/06/2012 9:11 pm
Unless it says Miele on the front, you can just pick it up and move it.
Miele were the only washing machines I delivered that needed 2 people.
Sack trolley is handy if there is a fair bit of distance.
Posted : 10/06/2012 9:16 pm
I moved our Miele from our previous house with nothing more than a Black & Decker trolley. Of course it rolled off on the drive onto its front (never try and catch one!). I'd locked the drum and the damage was limited to nothing more than a couple of scratches to the plastic. It's been running fine for the past 18mo.
Posted : 10/06/2012 9:25 pm
Who cares about the washing machine? Where did he bring his flat from?
Posted : 10/06/2012 10:28 pm
 Ewan
But when I flog the flat i'll need to get rid of it anyway.... who wants a 6 year old Beko washing machine? (other than me, since it's working fine)
Posted : 10/06/2012 10:51 pm
Fair point.
If he can move a whole flat, the washing machine should be a piece of piss to shift :mrgreen:
Why get rid ? Just say white good included. Youll only be sick when you get it to new house and it only works for a week 🙂
Posted : 10/06/2012 10:57 pm
On a "they don't make them like they used to" basis I've never paid for one, just got them free whenever people have upgraded for some reason on the basis that they seem to fail rather than wear out so an old one's as likely to conk out in a year as a new one and the bits that do wear tend to be cheep.
Posted : 10/06/2012 11:13 pm
Friends help you move.. real friends help you move dead bodies.
Posted : 11/06/2012 12:21 am
Moved 3 washing machines with my girlfriend, they're not particularly heavy but you can often take the concrete out if you're feeling lame. Otherwise, use a whatsit truck.
Posted : 11/06/2012 1:58 am
Moving a washing machine up or down stairs? Best to get a couple of friends from the rugby club. Some beers afterwards make it a reasonable quid pro quo. The modern world of key tapping and carrying a laptop has stolen my birthright of heavy object moving. +1 on the Miele comment. Other washing machines almost float when picked up, compared to a Miele.
Posted : 11/06/2012 7:13 am
