House insulation - ...
House insulation - avoiding thermal bridging
We're installing internal wall insulation (old house, solid brick walls) and from what I read a major problem can be thermal bridging, where you have a less insulated gap that gets cold, produces condensation and then you have a horrible mould problem, all the joists rot and the house falls down.
I'd like to avoid this, ideally...
The installer is a local plasterer, comes recommended but I doubt is an expert on insulation.
It'll be insulation backed plasterboard, stuck on all the external walls (after removing the old render/plaster back to brick).
My main concern is in the gaps between floors. How is this best avoided? Do I just take up the floorboards around the edge of the 1st/2nd floors and insulate the bit of wall there? With what? Glass wool stuff? Expanding foam?
Anyone have experience with this, or just good ideas?
Posted : 29/12/2022 5:02 pm
 ajc
You need to get the property assessed by someone that knows what they are doing. Don’t put foam backed plasterboard in a solid walled house with lime mortar. Breathable materials only in an old house and you will need to have a robust ventilation strategy at the same time.
But back to the original question, yes you will have a thermal bridge. You will need to insulate the inter floor area. You may well need a wufi calculation to work out if your joist ends are likely to rot. Don’t leave it to a plasterer to tell you what to do
Posted : 29/12/2022 8:46 pm
