Anyone know where I can get a hose fitting the some as the ones in this link please?
https://www.amazon.co.uk/gp/product/B00ZGZDCWC/ref=oh_aui_detailpage_o02_s00?ie=UTF8&psc=1
Both of the fittings that came with the washer have broken.
Aren't those just regular Hozelock hosepipe connectors? You can get Hozelock and cheaper unbranded equivalents in B&Q. Theres usually a little pick and mix rack of them in the gardening bit
Screwfix and Toolstation do them cheaply too
The pipe is a lot smaller than regular garden hose.
Around 10mm OD 6mm ID.
So would a regular hose lock connector still fit to it though? It looks a lot like a hozelock fitting. You'd maybe just need to find a way to step down to a narrower hose.
There's a Hozelock adapter for thinner hoses (like the Mobi). It's a tight squeeze but it works and you can then fit any Hozelock pistol etc.
If both fittings have broken (and a hozelock 'female bit' fits the male nubbins on the pump and pistol) just use a regular bit of hosepipe.
Any links to one please?
The external thread on the outlet of the pump is an odd size.
If the thread ain't BSP, it will be NPT
Are you sure the hose is 1/4" bore, from those pics I'd guess 3/8" bore, quarter would be massively restrictive, 3/8 is fairly common in low end garden hoses
Yep measured the hose as 10mm od 6 mm id.
I presume they use small bore hose to help keep the pressure higher and use less water.
Hmm, that complicates matters, I'd then suggest going to your local hydraulic place, like Pirtek, Lancashire Tanks, or such and going the adapter route, say for instance 1/4"firtree hosetail to BSP or NPT swivel female- hose clip these on to your existing hose, and adapt up to the hoselocks which I'd guess at being 1/2"bsp female
Are you talking about the female bayonet connector ?
(The light blue one...)
If so, a std hozelok should work.
To get your hose to fit, slide the nut onto the hose first, then hold the hose in boiling water for a few mins, it should soften up enough to go onto the back of the bayonet.
Cheers all.
I'll try the Hozelock scotroutes has linked to.
Try nomad - they used to keep spares but seem to have ceased doing anything useful.. they may have those though. Mine is the same size.
