Hope V4 Calipers?
Hope V4 Calipers?
I've read in a couple of places that Hope V4 calipers need a different mount that E4. But I'm not really seeing which one i would need to run a 203 rotor up front on a set of Fox 38. So it's probably so obvious it's staring me right in the face. If anyone knows which one could you let me know.
Much appreciated
Posted : 15/10/2024 9:23 am
Pretty sure a Fox 38 is 200/203 minimum rotor, shouldn't need an adaptor
Just checked and t's actually 180 so ignore the above
Posted : 15/10/2024 9:25 am
Definitely doesn’t need a different mount, the only difference is the size of one of the pairs of pistons,
Posted : 15/10/2024 11:06 am
Depends on the mount you had. e4s work fine with the likes of Shimano, where a v4 wont as the big piston clashes with the mount. However if you have Hope mounts (or SRAMs IIRC) you can use them for both.
Posted : 15/10/2024 11:12 am
Brake_Adaptor_Mounts_2021 (hopetech.com)
L is the common +20mm  ie 160>180 or 180>200
H is the +23mm ie 160>183 or 180> 203
Posted : 15/10/2024 11:13 am
You need to use the hope brand mounts, shimano interfere
Posted : 15/10/2024 12:00 pm
Perfect,  cheers all
Posted : 15/10/2024 12:08 pm
Shimano interfere until you hit them with a file or a Dremel. I've definitely done this as an emergency stopgap and then left it in place for years.
Posted : 15/10/2024 1:28 pm
Same with the Sram adaptors on one of our bikes.
Couple of minutes with a file to get them both to fit.
Posted : 15/10/2024 3:31 pm
And the space between the pads is wider to accommodate the vented rotors(3.3+mm)
Posted : 15/10/2024 6:14 pm
Another one here who took a grinder to a Shimano adapter, and is still alive to tell the tale...
Posted : 15/10/2024 6:26 pm
