Community
Home electrics - wi...
[Closed] Home electrics - will I die?
Are there any sparkies on here?
I’ve got a device that uses a transformer with a two strand output and a large right angled connection on the end - similar to this one:
https://picclick.co.uk/Replacement-for-12V-120V-15A-125A-10A-075A-401394458109.html#&gid=1&pid=1
The device has to be in a particular location to work properly - and getting the power to it means drilling through 3 x 15cm solid walls. Due to the connector on the end this means 25mm holes to get enough wiggle room.
Rather than destroying the house with massive holes could I snip the end off the cord, poke it through a smaller hole and then use a choc bloc to rejoin the cable?
The output is 12v / 1.5a if that makes a difference.
Thanks in advance for any expert advice.
Posted : 11/03/2019 10:51 am
12v in the cut wire? You'll be fine. Make sure you label the two strands before you cut so you reconnect the correct ones to each other.
[edit] although tbh why not use the holes to just run a mains spur out to where you need the 12v power and not worry about cutting the wires ont he transformer?
Posted : 11/03/2019 10:53 am
If you struggle to mend the cable after it's been split can you get hold of another adaptor easily?
Posted : 11/03/2019 11:38 am
Don't use a chock block, use something like a wago connector, much safer and all round a better product
Posted : 11/03/2019 11:44 am
Snip the cable, drill the holes and use a 10 or 12mm plastic pipe through each wall to act as a 'conduit' / makes it easier to push the wire through.
Posted : 11/03/2019 2:06 pm
Of course it makes a difference.
TBH even a choc block would be overkill. You could just strip them, twist them together and tape them up. If you want to be posh use heat shrink tubing.
Posted : 11/03/2019 2:14 pm
Yes. Everyone dies...
Posted : 11/03/2019 8:50 pm
