Was working well, then moved rooms and i cant get it to go online, where do i find the WPA key or the WEP
The WPA key will be the same as it always was. Perhaps there's no signal in the new room?
Your ISP will have given you the WEP key...
its showing signal strength as 82% ๐
Was it working via wireless before?
82% is quite high. As long as you have signal it should be able to connect. You should use the WEP key. probably came with your modem: on the base of the modem or in the cd case to install the modem with.
Can get wep key by logging onto router.
yeah it was
So if it was working, and all you did was move rooms, what's different? Signal strength can be high remember, but signal quality can be low. Noise can be an issue.
No, only if your using their router and setup.
Connect with your computer the router and look for wep key in admin settings.
You need to speak to the keymaster
Have you tried turning it off and on again?
