I'm looking at getting a Neo 3c.
I've got the install manuel here:
I'm reading it as 150mm at the rear and sides from "non-combustibles" and 500mm from combustibles from the side or front.
It also says the hearth must protrude at least 300mm in front of the appliance and 150mm either side of the appliance.
Does that basically mean that I can't get it far back on an angle in the corner of the room as to get the 150mm distance from the back corners it'll be quite far forwards?
Am I better going square with the walls to save more space?
Is it good practise to make the size of the hearth on the outside edges the minimum combustible distance ie 500mm not the stated hearth minimums of 300mm (front) and 150mm (side)
Posted : 20/10/2018 9:26 pm
