[Closed] help me mend my shower
Its a Grohe mixer fed from a combi boiler. Not sure of the model; its not on their current web site. Its got 2 dials situated in concentric circles with the temperature being the smaller mounted in the front.
Over the last 3 months its been getting less hot, not problem really, just turn it up a bit. But now its at the point where its not getting hot enough with the thermostat turned right up as far as it goes.
No problem at all with hot water from the boiler elsewhere.
My guess is
1. Hot/cold mix has gone out of adjustment
2. Thermostat needs replacing
3. Boiler problem
I reckon I could try (1) myself because if it is that I'll save myself alot of hassle and money. However I'm buggered if I can work out how to get the bloody thing apart! Anyone know before I get a plumber in?
no idea, but there's often a front panel that pulls/ slides off to get to the gubbins inside
Its all mounted externally, no front panel
Has it started to drip from the shower head when turned of...even a little?..if so then the main culprit is probably the cartridge which sits behind the main body of the control. These are prone to breaking down over time and as a sign often tend to let water through even when closed. You can get replacements quite readilly but they cost a bit and are fiddly if you dont have the tools or experience. Check the warrenty as my Mira packed up last year after only 2 years and Mira sent some one out and sorted it under warrenty...even though the reciept and warrenty form were not to hand.
if you hold on showerman might show up.
Hit it with a plumbers wrench?
is you're water pretty "hard"? sounds exactly like a problem i've got with the electric showers here at work... hard water = crudded up heating elements = slow to heat up, poor power output and lower temperatures ๐
Is it a thermostatic tap? There are plain mixers and then there are those with thermostats inside to stop you freezing or scalding yourself. It may be broken.
If the feed to the bath is still as normal and warm. ie the same as it always has been, then I would bet on the problem being with the thermostat valve in the shower mixer. I'm not sure how easy it would be to replace but I can bet it won't be cheap.
this sounds like a dodgy case for sexual entrapment to me!
STWer turns up to help
goes in to shower, starts work
"would you like a cup of tea?"
"sure"
/rohupnol in tea
tea drunk, water "accidently turned on"
oh lets get you out of those wet clothes... ...etc ๐
DEVIANTS! THE LOT OF YOU!!!
PMSL at mrNutt !
