Help - Buffalo NAS ...
[Closed] Help - Buffalo NAS has failed
My Buffalo Linkstation is no longer recognized by the network and I need the data! I have read that if I download a boootable Knoppix DVD then I can boot with this and copy the data off. Where can I download Knoppix and is this even possible or is there another way to do it?
Posted : 25/10/2012 5:46 pm
Have you tried googling 'download knoppix'? :)... [url= http://lmgtfy.com/?q=download+Knoppix ]in fact...[/url]
First thing I would try would be to plug the drive into a computer without going through the hub/router. I'd try a boot disk as well, if that doesn't work you could but a usb caddy for the drive
Posted : 25/10/2012 5:50 pm
Tried a caddy but no good. Will try USB but need an unusual cable as both ends are standard USB!
Posted : 25/10/2012 5:52 pm
Does it have a utility to login to it where it searches for it?
Sounds odd but my Netgear NAS once lost it's IP and assigned itself one in a different range to the LAN meaning I can't see it over the normal route, but the utility could see it so I could correct the IP
Posted : 25/10/2012 5:55 pm
Have you tried a caddy when running linux on your PC? I know very little about this but have a linkstation and think I remember something about needing to use a bootable from USB version of linux or something. I thought there was a linkstation forum or wiki somewhere with loads of info, maybe google that. If I sound vague that's because I don't know what I'm on about. ๐Ÿ™‚
Posted : 25/10/2012 5:57 pm
Phew, managed to fix the drive this morning by flashing the firmware. Have copied all files off and will now bin in favour of a more reliable drive and back this up!
Posted : 26/10/2012 12:05 pm
