Now that the mancave exterior build is nearly finished, started to plan inside now.
Going to sort some insulation first and wondered which type to go for, celotex type or rockwool or a mixture of both - use rockwool type on walls and celotex on ceiling?
Not sure how long it will take to get power sorted but seen lidls have [url= http://www.lidl.co.uk/cps/rde/SID-81C8F2EE-97043975/www_lidl_uk/hs.xsl/our-offers-2491.htm?action=showDetail&id=7184 ]THESE[/url]which look a good price? Or use a gas bottle type heating for now....
Any thoughts?
Cheers.
first thought is I hate handling rockwool
second is it seems wrong to spend money on electricity heating a man cave. I am planning a wood burner as I keep seeing them on offer at Costco: http://www.costco.co.uk/view/product/uk_catalog/cos_2,cos_2.8,cos_2.8.1/140525?utm_source=emailFY14P2W4a&utm_medium=Feat-8&utm_term=140525&utm_campaign=emailFY14P2W4a
That one looks a bit overkill for a mancave ^^^
[url= http://www.machinemart.co.uk/shop/product/details/potbelly-cast-iron-stove ]stove[/url]
used insulation?
[url= http://www.secondsandco.co.uk/ ]Insulation[/url]
I lined mine using Celotex on floor, walls and ceiling:
[url= http://farm9.staticflickr.com/8485/8258394476_842199275c_z.jp g" target="_blank">http://farm9.staticflickr.com/8485/8258394476_842199275c_z.jp g"/> [/img][/url]
[url= http://www.flickr.com/photos/brf/8258394476/ ]First insulation later complete[/url] by [url= http://www.flickr.com/people/brf/ ]brf[/url], on Flickr
[url= http://farm9.staticflickr.com/8491/8267368845_23120d32d1_z.jp g" target="_blank">http://farm9.staticflickr.com/8491/8267368845_23120d32d1_z.jp g"/> [/img][/url]
[url= http://www.flickr.com/photos/brf/8267368845/ ]Fitting Celotex PB4050 onto GA4100[/url] by [url= http://www.flickr.com/people/brf/ ]brf[/url], on Flickr
I've just bought a dehumidifier which is running 24/7 on its humidistat. Not sure what I'm going to do heat wise, will probably have an oil filled electric radiator on a timer for when it gets really cold. Right now I just want to make sure it doesn't get too musty.
Its really worth remembering that drafts are worth addressing every bit as much as insulation.
All that work and you still need to run a dehumidifier ? What went wrong ?
Its worth remembering its a shed at the end of the day.
I don't know that I do, but given it's unheated, I'd rather make sure the humidity is kept low, as once you get mould it's a pain to get rid of.
Only shed i get mould in has a porous roof.
not much point in adding £££ insulation unless you are going to heat it - electric fan heater probably best to quickly warm up areas like that
I use a gas bombola- but if your going to plug up all vents your going to not want to use a gas appliance.
Equally with no ventlation your going to get no air movement. Stagnant air =
must be a grand on insulation there Footflaps?
Remember now all that celotex in yours footflaps. Depends on costings again I guess. Good point re humidifier, mine needs to dry out a tad so may try and borrow one for a while.
I would like to put a stove in there at some point but as I'm going to run electric up there soon(ish) I thought some sort of electric heater that's programmable would be ideal to put on for an hour or two here and there?
Agree that first stove is mahoosive but the machinemart one might be better size wise but still over 6KWh!!
I'll check out the 2nd hand insulation site think they're on ebay as well?
Frontier stove?
Oh yes, remember those from a previous thread. They look good but dont they take up some room with the legs?
Is there any real need to heat it? I've never bothered to heat a workshop, year round I work with the doors open.
Its not that big either.
I have a 25ft by 10ft bt 8 ft high garage. Ive celotexed the roof but besides that its just singleskin block. 20minutes with the bombola has it heated for the night.
A woodburner will just be getting up to speed when youll be finished what yer doing.
Did anyone see the "Great big energy saving challenge" on bbc2, just finishing now. They had a solar air heater, which looked amazing! Lines of drinks cans, glued together and sprayed black, in a glass fronted frame and then feeding through an insulated ducting into the house, was pumping out warm air into the house at 30 degrees for free. There must be a catch though. Although without sun or bright daylight, it must be useless. So nights would be cold
I ran a solar oven workshop once. Quite good fun, there are hundreds of designs each aimed at a particular culture or economy (whether a certain population makes or buys stuff and whether goods are manufactured locally at a cottage industry level). Each design also takes into account when in the day people eat and where the sun is at that time of day at the latitude. Some are are satellite dish fresnels that point up for cooking in the middle of the day at the equator some are like clamshells for cooking breakfast and supper when the sun is low. They can be quite beautiful.
They require less sun than you'd imagine - our workshop was in the context of humanitarian aid and survival so the goal was to be able to pasteurise water - get it to 70degs. With a tinfoil wrapped cardboard box, a cooking pot painted black and clear polythene bag we were able to get the water in the pan up to 70 degrees in about a 20 minutes on a lincolnshire october afternoon
I'm saying nothing!
Any links for a bombola type heater?
About £2.5k if I recall, something like 60 8x4 sheets.
That's what I use when I'm in there and it only needs a 10 min blast to warm it up. It's only the last few weeks I've had to think about this as it's spent the year so far with all the Veluxes open on their latch about 1".
http://www.calor.co.uk/shop/product/calor-heat-portable-heater-without-gas/733/
its something like that i have .
got it FOC
made sure the garage has plenty ventalation
Double bubble foil insulation has my vote. So much warmth for 1 tiny layer of insulation. So easy to just Staple into position too.
That's just asking for trouble.
I'll get my coat.
Can you elaborate?
Macbeth?
You might want to [url= http://www.thedailymash.co.uk/news/society/wood-burning-stove-brings-authenticity-to-middle-class-mans-life-2013110180842 ]read this[/url].
Was tempted by one of these but thought it might look a bit lost in my 'shed'
[url= http://www.salamanderstoves.com/docs/52/the_pipsqueak__stove/ ]Pipsqueak Stove [/url]
Ended up fitting one of these...
[url= http://www.stoveworlduk.co.uk/coseyfire-stoves?product_id=121&sort=p.price&order=ASC ]Cheap stove [/url]
Have one of these too...
[url= http://www.amazon.co.uk/Delonghi-Dragon-4-TRD4-0820ER-Electronic/dp/B00C2354IQ ]Oil filled radiator[/url]
Macbeth?
Christ! You've done it now
[quote> http://www.calor.co.uk/shop/product/calor-heat-portable-heater-without-gas/733/
got it FOC
I have one of these "super ser" heaters good job for the garage and easy enough run when kept on the lower setting.
[i]About £2.5k if I recall, something like 60 8x4 sheets.[/i]
Seriously?
68 sheets in total. Can't remember the actual cost, but at, say, £35/sheet it would be £2380
This was the first batch, 100mm on walls & floor, 75mm in between rafters
[url= http://farm9.staticflickr.com/8062/8251282511_45da71c887_z.jp g" target="_blank">http://farm9.staticflickr.com/8062/8251282511_45da71c887_z.jp g"/> [/img][/url]
[url= http://www.flickr.com/photos/brf/8251282511/ ]1st shipment of Celotex (38/68 sheets)[/url] by [url= http://www.flickr.com/people/brf/ ]brf[/url], on Flickr
This was the 2nd layer, 50mm foam PB backed on walls and over rafters
[url= http://farm9.staticflickr.com/8350/8266974814_4f295b6016_z.jp g" target="_blank">http://farm9.staticflickr.com/8350/8266974814_4f295b6016_z.jp g"/> [/img][/url]
[url= http://www.flickr.com/photos/brf/8266974814/ ]30 sheets of Celotex PB4050[/url] by [url= http://www.flickr.com/people/brf/ ]brf[/url], on Flickr
Smaller bords I know but used for price comparison: http://www.toolstation.com/shop/Construction+Materials/Insulation/Celotex+Insulation+Board+50+x+1200+x+450mm/d210/sd2738/p10635
Works out at about £1800 for just the boards in 50mm + fittings and tape etc. Scary how it mounts up!
I am planning on building my whole shed for less than that. We'll see how that plan goes though...gulp! I will be a business expense though.
Just dug out the prices:
10 sheets Celotex GA4000 75mm (Insulation express do this at £23.76 ex VAT)
28 sheets Celotex GA4000 100mm (Insulation express do this at £30.24 ex VAT )
30 sheets Celotex PL4000 50mm+12.5mm P/B (your web price is Price ex VAT: £33.98)
