Heart rate monitors...
[Closed] Heart rate monitors - iphone Apps
After the Lidl PSA I picked up a monitor yesterday.
Are there any apps I could use for indoor training/monitoring that work on the iphone? Have got it working with Strava but would like something that works indoors when I'm on the turbo trainer. Ideally want something that charts time/bpm.
Thanks
Posted : 19/03/2015 10:45 am
I use the 'wahoo fitness' app when im on the turbo.. find it brilliant.. and it does export to strava too..
I use android but there is an iphone version
I do have a wahoo heart rate monitor, but the app connected perfectly fine with a runtastic speed/cadence sensor..
there are several easy to read screen layouts you can choose from too to see what data you need,
and the 'burn / burst' system they use is quite an easy indicator when you might not be in a fit state to work out which zone you should be in! ๐Ÿ˜†
Posted : 19/03/2015 11:08 am
Cheers spacehopper, will give that a whirl, much appreciated.
Here's 7 karma points to use as you see fit.
Posted : 19/03/2015 12:48 pm
