Hard to treat cavit...
[Closed] Hard to treat cavity wall
It's a 45mm cavity.
Single storey ground floor, two walls totalling maybe 6m run.
The energy advisor said 'no can do' as the cavity is too narrow. I also think the job was too small.
I'm having the roof done in a couple of weeks, ideal time to fit some top of wall cavity closers.
With that in mind I see there are some companies that do poly beads in such walls.
Been in the house 5 years, no damp at all, only condensation mould on those two walls.
Thoughts?
Posted : 15/05/2019 2:09 pm
Bump
Posted : 15/05/2019 9:43 pm
External wall insulation. Extend the roofline while you’re having the roof done.
or Internal wall insulation depending on what’s on the inside face of the wall.
Posted : 15/05/2019 9:55 pm
Sadly I'm not going there, we had new windows a couple of years ago, plus issues of drains and detailing mean it would be mega expensive.
I can go for internal, I was hoping to not faff with the room, but no real problems to do so.
So the cavity is just a leave alone job?
Posted : 15/05/2019 10:15 pm
If it’s only 45mm I’d say it was a non starter. Not a fan of cavity fill unless it was designed in to begin with.
Insulated plasterboard internally probably your simplest option.
Posted : 15/05/2019 10:19 pm
That's the plan now then.
House is dry and warm - of just classic cold wall surface behind furniture etc that develops mould in winter.
Posted : 15/05/2019 11:02 pm
Did my entire house on the inside.
Posted : 15/05/2019 11:13 pm
