...just found out I will need to scrape about 3mm door bottom when i fit the wooden floor 👿 ..seems cheaper option is to hand plane it, 2 standard doors im sure wood is soft and nothing special, how hard could it be?
They do an electric for just a fiver more. Easier to cope with the glue and joins on the bottom of a door. Set it to a fine cut and do lots of passes rather than rushing it in one or two shoves.
It probably will but an electric one is easier. The grain on a solid wood door will run in different ways across the bottom as they are made from panels. Cheap electric ones are about £25.
Or bung a pro 20 quid to do it for you. 😉
...aye - good luck getting a joiner out just to shave a bit off a door! 😀
If it makes you feel better I've got 10 new doors arriving on Monday and her indoors expects them fitted by Friday.... 🙁
Thats my trade and I regularly pop into peoples places to shave doors on the way home from work. Less than an hiur to do a couple of doors (beer money) yay
Cool... See you Monday... 😉
i also plane doors, strange you go out to plane a few doors, and then geret remembered for bigger jobs, so a bit like reverse advertising.
Electric planner, keep finger out of cutters, only plane half way down each edge, or it will spelch out, dont put mobvving planner down until blades stop, and ensure you plane the base not top of door, easily done.
Given my planing skills I prefer to use a router and do half the door thickness from one side and then finish it off from the other using a nice straight edge clamped to the door to follow. Makes a hell of a mess though!
If you do it yourself make sure you mark how much you want to cut off before you start. This was a £300 lesson I learnt....
cheers guys, will try to find a good enough electric plane for 2 doors job..
what do you mean by this exactly? to be honest I haven't seen how electric plane do the job like and only seen the hand wooden plane when I was a kid
The stile/edging/lip of the door will be in the form of end grain at the bottom of the door. If you plane against end grain the timber will split at the point the plane exits the material.
It needs a scrap block to avoid that
Much easier though of course is to plane half way and then change direction.
best to get a man in to do it,
I've known women who were capable.
But this man needs the work, recession and all that
Has this man got any tools ?
Use a belt sander!
