Guitarists of Singl...
Guitarists of Singletrack...
There’s a Gibson Tribute Firebird on Facebook Marketplace in Wigan if that’s any good to you.
I guess it’s gonna be hard to try one before you buy, so a used Epiphone to see if you get on with the shape would be the ideal bet. All I ever listed after was a proper Les Paul but when I finally got one I realised it wasn’t the best fit for me.
IMHO, if you’re gonna spend that much money on an unknown, go and try one.
Posted : 12/04/2023 9:06 pm
Heh heh, brilliant plan @eddiebaby!!!
Posted : 12/04/2023 9:36 pm
“…If you want the fire bird vibe in an easier shape then ~Ivison Dakota…’
£4,250!!!
Looks ace but more of a LP vibe to me, plus it’s not a “Gibson” - Remember this is a case of irrationality here, no room for actual logic 😉
Posted : 12/04/2023 9:41 pm
Ok, so Gear4Music have the Epiphone Firebird for £549 to order which is £100 less than others with deliver for 6th May, one day after I turn 46. I followed the advice and decided to go for this one, and then put my name on a waiting list for the ‘proper’ Gibson. Hopefully by buying it now, when the stock come in they’ll fulfill preorders first and I can get hold of it at the lower price than GAK etc al…
Posted : 12/04/2023 10:38 pm
Damn, now youve got me looking. Just looking!!!
https://reverb.com/uk/p/gibson-firebird-studio-non-reverse
Posted : 13/04/2023 10:37 am
The more I look at guitars, the more thankful I am that I started out a bassist because there are so many more awesome looking guitars - if basses were like that my house would be full of them! Thankfully the ergonomic nightmare of basses (if you play like I like to) massively shortens the list of ones that look cool and play well…
That Firebird is a prime example - it’s sister bass the Thunderbird also looks really cool but they are not great to play unless you’re 7 feet tall or just want to bang out 8th notes as it dangles around your knees.
I’ve been looking into building a guitar pedalboard for work demo and recording purposes - I seem to be getting sucked into these JHS pedals that contain multiple clones of the Tubescreamer (9 versions!), Big Muff (6 versions), and Rat (9 versions). Fully analogue signal path with a microprocessor switching loads of components in each.
Was going to get a compressor pedal and reverb too but then realised I’d have no modulation pedals (unless I used my bass pedalboard) so maybe I should get an HX Stomp for the compression, modulation, delay and reverb? Plus we can use that for amp/speaker modelling demos with both active and FRFR guitar cabs.
Posted : 13/04/2023 10:52 am
The more I look at guitars, the more thankful I am that I started out a bassist because there are so many more awesome looking guitars – if basses were like that my house would be full of them!
Same. There are endless awesome guitars available but luckily I don't know how to play them.
I have a Mexican J and a Squier P and I can't really justify anything else and there are no basses that I really lust after. I'll probably by a Stingray Special one day and then I'll be done.
My most likely next purchase will be one of the DIY kits from Thomann just so I can do a crazy paint job without wrecking anything expensive.
Posted : 13/04/2023 11:14 am
I think this is a good thing once you've got more than 2-3 pedals. It just gives you loads of options. Want to try a phaser for a specific song? No problem. Want a different Reverb? Fine. Want a weird delay? There are loads to choose from. Want to A/B a loop via different cabs? No problem, it's got a looper built in. Plus it makes it really easy to record - just plug in via USB using an amp/cab sim.
That looks great, but I wouldn't count on it arriving on your special day...
Posted : 13/04/2023 12:39 pm
Danish Pete jamming over a loop with a single pickup Esquire. Darn it sounds good with so many tones.
Posted : 13/04/2023 7:29 pm
He could make a 50 year old Eko acoustic with 1" action sound good
Posted : 13/04/2023 7:48 pm
I may just have a guitar to sell him then...
Posted : 13/04/2023 8:39 pm
This has been quietly doing my head in over the last couple of weeks. Closest I can get so far with the camera running……
The irony is that Peter Green probably played it that way once into the tape and never played it the same way twice!
Tone is the guitar straight into the orange rocker I posted before if anyone is interested!
Posted : 17/04/2023 2:03 pm
simondbarnes reacted
Sounds bloody good to me!
I'm trying some Hendrix this week
https://youtube.com/shorts/FV1lDvlyKOI?feature=share
Posted : 18/04/2023 10:00 pm
True
Much better than any Gibson I've played but a pencil must be lead
Posted : 19/04/2023 9:03 pm
I impulsively bought a SC20H and SC212 and instantly regretted it!* I’d not realised that there was only one channel and no foot switch for clean/OD. So I’ve decided to cancel the order and am now looking at DSLs. I’m torn between a 20 or 40 and will most likely go combo. I think the 40 has better options for the 2 channels but do any of you have any real use experience please?
*Also partly financial reasoning as I’m only just getting back into this guitaring again and think a DSL will be more than enough for me at the moment.
Posted : 19/04/2023 11:26 pm
If you like the Marshall overdrive sound then the DSL is a good choice. However the SC20H and the OD pedal of your choice is more likely to get you the sound you want. I've got a JCM 2000 TSL, the clean channel is ace, crunch channel typically overdriven Marshall and the lead channel frankly a fizzy unusable horror. A Tubescreamer on the clean channel gives a nice overdrive at the click of its footswitch.
All the Marshall amps I've used have been toppy and the Marshall lead circuitry accentuates that. However, the clean channel with plenty of gain and volume gives that classic Marshall sound. At painful volume levels though, I hope your home is well sound insulated and you have -20db ear plugs because that's the kind of volume they sound best at.
What are you going to use it for? I've never yet used my Marshall on stage. It's a hoot to play in rehersal but I'm lead vocal and second guitar - The stage plan for our next gig shows me with Fender Bassbreaker 45, 112 Orange cab, a pedal board and a Shure SM58 - because that's the sound the other members of the band approve of.
Posted : 20/04/2023 11:38 am
New Amp Day! I was driving from Folkestone to Somerset via Milton Keynes Tuesday/yesterday, so I thought I might as well make a stop at a few guitar shops. First time at Anderton's (impressive stock, staff didn't seem that interested) and then popped into Rock Hard Music in MK (bizarre and blokey place with a massively sweary guitar tech just out of sight obviously struggling with a repair. Finally popped into PMT in Cowley/Oxford and had a great time. Nice selection of gear and happy to listen to my demands - basically, I've got loads of big amps and gadgets at home (too many to be honest), but I'm after a portable amp to take round to a mate's house for the odd blues jam. Even my smallest setup is still a pedalboard and micro amp into a cab, or a surprisingly heavy Epiphone Valve Junior in a Blues Junior cab. Or an HX Stomp and a powered PA speaker.
I was thinking something like a Tone Master Princeton, but was open to other ideas like a power-amped pedal as I have a superlight and awesome Barefaced 1x10 cab (of this parish). I ended up trying a Deluxe Reverb TM (they didn't have a Princeton, though I did see one at Andertons) and a Blackstar Amped 1. The PMT staff were super nice and I was able to grab a guitar of my choice off the wall and noodle away in a soundproof booth with both amps. The Deluxe was lovely, Very hard to get a bad sound out of and loud as you like. However, it's still too big/clumsy to carry half a mile down the road - I think the Princeton is too, to be honest. So I went for the Blackstar Amped 1 - 100W powered pedal, (with FX loop and 500mA power for other pedals) - it's harder to get a stunning tone out of, but not really that difficult, and it'll go from super clean (and loud!) to (just) 80's rock sounds with the twiddle of some knobs. There's one preset, which effectively means it can be used as a two channel amp. So now I can have an 'amp' with reverb in a gigbag with a guitar and carry my 1x10 - job done!
Of course I don't have a guitar with me, so I'll have to wait for a bit to give it a proper try at home. And I may yet get a Princeton or Deluxe for home playing in the future. Very impressed with those. Anyway... ta daaaa!
Posted : 20/04/2023 1:21 pm
nice - that will pair up with your HX stomp too because you'll be able to use the HX as your effects options into the amp
Posted : 20/04/2023 1:53 pm
Yes, there's a flat response amp option for just that kind of behaviour. I'm hooked on the HX Stomp Litigator amp model...
See? I'm already building it into a bigger pedalboard...
Posted : 20/04/2023 3:49 pm
See? I’m already building it into a bigger pedalboard…
Well you do have a reputation to maintain 🙂
Posted : 20/04/2023 4:03 pm
What are you going to use it for? I’ve never yet used my Marshall on stage. It’s a hoot to play in rehersal but I’m lead vocal and second guitar – The stage plan for our next gig shows me with Fender Bassbreaker 45, 112 Orange cab, a pedal board and a Shure SM58 – because that’s the sound the other members of the band approve of.
I have a studio in an old barn at the end of the garden which backs into a pub garden so noise isn’t much of an issue. As I said I’m getting back into playing again after hip issues mean biking is limited and after an electric setup in addition to my acoustic. I’ve ordered the Epiphone Firebird and just pulled the trigger on the DSL40CR, and PEDL-91016 which should open up the onboard options a bit more.
Posted : 20/04/2023 6:26 pm
I went a different route to a Marshall tone.
I posted this on the Gear Page at the weekend.
Even more in love with my GTK Core today.
I took the Origin Cali76 and Revival Drive Compact off the miniboard and just ran a Dirty Little Secret into the front of the Core. The DLS was in Superbass mode and on 9v. Drive was fully wound up, bass totally cut with the mid cut slightly.
In the Core I had a single Transparent amp block with low gain and the output level up a ways. The cabs I changed to 4x12.
The effects were a simple pan delay a very light stereo chorus just for 'width', a bit of room reverb and crucially the Mastering Fx on Live Comp mode.
Those three FX set to use the three footswitches and then with the volume, tone and 5 way switch on the Tele I can go from an almost acoustic clean sound with light chorus sound to an awesome Marshall crushing Crunch.
I keep forgetting how dynamic the DLS is and the Transparent amp in the Core was a perfect pedal platform.
I could gig all night on that one amp model and guitar.
Brilliant.
I'm going to do a lot more experimenting with the Mastering Fx.
I can record from this or run it into an FRFR or Barbie's PA and to me it sounds and feels great. I'll try to record some samples later when i get back from work.
Posted : 20/04/2023 7:24 pm
That’s a pretty thorough tour of guitar shop Chipps! We’re actually working on some active Barefaced guitar cabs so I hope to have a tidy solution for any pedalboard/modelling focused players soon - which is also why my in-progress guitar pedalboard will have a HX Stomp (ordered by yet to arrive) so we can delve deeper into that stuff.
I appear to be quite firmly hooked on playing guitar - it’s a mix of randomly working through the chords on popular songs, and figuring out what chords/parts to play on the songs I’m recording with my band (that has no guitarist but I think needs some guitar on recorded versions - although I think bass/drums/vocals will work as a live thing.
Everyone who said “you need a Tele” - yes, I’m pretty certain a now do! I’m playing a 1991 Squier Strat (unplugged) at home, which is fine for training my fingers and figuring stuff out. On bass I always took a one bass approach but with my limited guitar skills and the wide range of styles/tones I’m after I’m feeling that the (Sire L7) Les Paul and Gretsch 5420T (big hollowbody) would be well accompanied by a Telecaster for the more angular/rhythmic parts (my funk, reggae, afrobeat, post-punk etc influences appear to be coming out on some songs).
Posted : 20/04/2023 9:02 pm
Just been 'mugged' on the way home by a pub venue asking me to do a gig with a singer acquaintance who has been playing some of our jamming tracks to them.
She wants them to let her sing over techno backing tracks and me do live guitar on top of it.
I'm really not too happy, would have been nice to be warned. They did give me a lot of beer though.
And that was nice.
Should I call her Yoko?
Posted : 21/04/2023 10:43 pm
Nah, just play the gig. Junior hates it when I play over his techno tracks, I hope you do it better than me.
Can't hear the word Yoko without this playing in my head:
Posted : 21/04/2023 10:52 pm
Did anyone do the Dyfi Enduro when they use to have a local DJ with an incredible slap/funk bass player who would jam over the top of the tunes? It was a great show. I think Squarepusher has done similar stuff, but this was obviously a mate who played incredible bass, would find the key and then just funk his way over the tracks. It was brilliant!
And - @chiefgrooveguru - can you make me (well, not just me, can you make...) a neat, vertical 2x10 please? Otherwise I'll have to buy one of those nice Blackstar St James vertical 2x12s as they look nice and my lunchbox amps can sit on top. 🙂
Posted : 21/04/2023 11:13 pm
“can you make me (well, not just me, can you make…) a neat, vertical 2×10 please”
Absolutely! We’re basically just adding models to fill the niches when people ask for and then order them.
So I spent quite a long time playing three different Tele’s today, MIM Player, MIM Player Plus and MIJ. Really liked the Player Plus - great neck, good balance (hefty body), sounded good unplugged and lots of tone plugged in - series setting is great for heavier stuff, plus all the usual Tele sounds and no hum.
Posted : 22/04/2023 2:08 am
Yep, I think Player Plus is the sweet spot in the range.
Posted : 22/04/2023 8:33 am
I’ve just been thrown a curveball by investigating Reverend’s range. I like the guys at Reverend, they’ve always made interesting guitars and basses, I tried a semi-hollow with P90s a few weeks back and that played and sounded great - and they gave me a Wattplower 2 bass for helping out with some ideas on the Mk 2 version. And I’ve spotted they make a Tele:
Reverend Eastsider T
Eastsider T
Similar price to the Player Plus. Love that shade of blue! No series switch but a phase switch - and series could easily be added.
Posted : 22/04/2023 10:25 am
If you get that I have the wiring loom for an Am Pro II Tele you can have. A push/push on the tone pot switches the middle position between series and parallel. Should drop straight in, also has a Fender treble bleed built in.
Posted : 22/04/2023 10:49 am
That would be super cool Eddie, thanks! Have just dropped the boss at Reverend an email...
Posted : 22/04/2023 11:06 am
Has anyone got any top tips for taming feedback?
The band I'm in plays quite loud and feedback is a part of the music, but I'm finding my setup is *very* prone to it, to the extent that it's squealing if I'm not actively playing. What I'd like to achieve is a graceful descent into harmonic feedback.
The other guitarist in the band doesn't have this issue (at similar volumes) and I'm not sure whether there's some setup tweak I can make to tame it a bit.
Any suggestions on where to start looking?
Posted : 22/04/2023 11:24 am
Use less gain ( maybe not realistic)
Get in the habit of turning your guitar volume knob down when you’re not playing
Stand with your guitar as close to 90 degrees to the amp as possible Instead of parallel to It
Stand further away from your amp if possible?
Use some kind of noise gate pedal?
Realistically different guitars feedback different amounts. Anything hollow obviously is bad but different pickups do as well. Generally single coils are worse than hum buckets but even between different single coils there can be a real difference. For example the pickups in my jaguar are way worse and more microphonic than the p90s I have in a different guitar. That might account for why your other guitarist has less issue?
Posted : 22/04/2023 1:12 pm
 jca
Do you always use the same guitar, and if not does the problem just affect 1?
Microphonic pickups are sometimes an issue which can be helped with things like wax-potting or tape wrapping to stop vibrations moving the windings. A guitar tech may well be able to sort this, or pickup manufactures like Bare Knuckle offer this as a service. Alternatively, different pickups may help.
Alternatively reducing the resonant frequency which causes the feedback can help - look for a parametric eq pedal which allows you to select the frequency and width of the band which it affects.
Posted : 22/04/2023 1:21 pm
The feedback you do want is the sound waves vibrating the guitar strings - you get that by holding the guitar in front of the speaker. It's in tune with whatever notes you're holding down.
The feedbacks you don't want are body boom, pickup and electronic feedback. Body boom is when the guitar body vibrates, a real problem with acoustics, generally a low frequency that the body resonates at. Pickup feedback is often loose wires on the pickup windings vibrating, a high pitched squeal. Potting the pickups in wax may or may not cure it. Electronic feedback is whan single coil noise gets out of control, again sQuealing.
I've got some really nice sounding high output single-coil pickups that I can only use at low gain and without distortion pedals. I've learned to use stacked single coils on stage, either Seymor Duncan or Fender N3 in my Teles. The Strat I flick to position 2 or 4 if it plays up. The P90 and low output vintage Tele pickups are usually OK but sometimes... .
Posted : 22/04/2023 1:39 pm
Hmm, thanks folks.
The parametric EQ suggestion is one I'd not considered, that could be worth exploring.
The guitar has humbuckers, although of course the pickups could be microphonic to some degree. Maybe the other guitar player wouldn't mind my running his guitar through my signal chain to eliminate the guitars that might be worth a go!
At the moment I'm tending to use my tuner as a kind of "kill switch" which is ok for periods of prolonged quiet, but less useful when I'm supposed to be doing e.g. stabs over the other guitar's main riff line.
Posted : 22/04/2023 2:31 pm
If it does feedback squeals when your hands are muting the strings then surely it has to be a pickup issue?
Posted : 22/04/2023 6:35 pm
That's a good point I had not considered.
Ugh. I really dont need any excuse to continue window shopping the Bareknuckle website.
Posted : 22/04/2023 7:59 pm
You can wax pot them at home - I’ve not done it myself but it looks pretty easy:
https://www.stewmac.com/video-and-ideas/online-resources/learn-about-guitar-pickups-and-electronics-and-wiring/wax-potting-pickups/
Posted : 22/04/2023 8:11 pm
Nice guide, thanks 👍
I had also seen reference to wax potting but the how-to I looked at made it sound a lot more intimidating! This does look doable for DIY. I might give it a try.
Posted : 22/04/2023 10:25 pm
Can I just dump them in my Putoline fryer then?
Posted : 23/04/2023 8:17 am
So long as you don't mind redoing them after every 200 or so wet winter playing hours
Posted : 23/04/2023 9:19 am
Has anyone got any tips for sound recording on a phone? I'm fed up with the phone mic picking up the sound of passing cars and also random volume changes so am trying an external mic out. It's really sensitive so gets overwhelmed / distorts if I have any kind of volume on the amp. There is a volume setting on the mic so I've turned that right down and put the mic further from the amp (about a metre)
It definitely sounds loads better than using the inbuilt mic (if you ignore the rubbish playing - still camera shy) but I'm hoping there are ways to tweak it to improve things.
https://youtube.com/shorts/jfb8Df5gKoc?feature=share
Posted : 23/04/2023 4:30 pm
Depending on the amount of phone recording you are doing, the Lewitt Connect 6 might be worth a look. Can be used as a high quality audio interface for your phone as well as PC
Posted : 24/04/2023 9:10 am
Not enough to spend that amount of money 🙂
Was hoping there is an easy to use, free app.
Posted : 24/04/2023 10:17 am
you could try running it through some kind of free audio workstation like garageband - do you have a laptop to plug the mic into? using a DAW would give you the ability to balance the levels before hitting record and also a noise gate
Posted : 24/04/2023 1:45 pm
Anderton’s (impressive stock, staff didn’t seem that interested)
every single time i go to andertons its the same
Posted : 24/04/2023 8:32 pm
They are on the free delivery promise is bullsh1t list. Free UK delivery my ar5e
Some parts of the UK are classed as "remote areas" by our couriers which means delivery normally takes 1-3 days to arrive with you after dispatch. The following postcodes are affected:
AB31 to AB56*
BT1 to BT97*
CA4 to CA10
CA16 to CA27
CA95 to CA99
DG1 to DG2
DG3 to DG9*
DG10 to DG16
DL13 to DL13
FK17 to FK21*
G63*
G83 to G84
HS1 to HS9*
IM1 to IM99*
IV1 to IV63*
KA26
KA27 to KA28*
KW1 to KW17*
LA2
LA6
LA8
LA10 to LA23
NE18 to NE20
NE47 to NE49
NE61 to NE71
PA20 to PA78*
PA80
PH10 to PH19
PH20 to PH99*
SA19
SA31 to SA48
SA61 to SA73
TR21 to TR25
TS12
YO21 to YO22
ZE1 to ZE3*
* These remote areas are chargeable by weight starting from £6.99 for Northern Ireland and £9.99 for all other remote areas.
For delivery to the Channel Islands, please select "Jersey" or "Guernsey" in the COUNTRY field when entering your address. Prices start from £8.99.
Posted : 24/04/2023 8:59 pm
“Has anyone got any tips for sound recording on a phone?”
I use my iPhone as a dictaphone for songwriting and find the built-in mic and compression works well for that - I’m usually recording an acoustic bass guitar unplugged or sometimes a whole (quite loud) band in a rehearsal. For anything I want to actually sound really good then it’s all the messing with mics, interfaces, computers and so on - which I really can’t be bothered with until I have to!
Currently writing this whilst my vocalist puts down some scratch vocals on a demo - she’s bloody good! 🤘
Posted : 24/04/2023 10:35 pm
Cheers @edhornby and @chiefgrooveguru
For some reason the inbuilt mic in my phone give really inconsistent results.
Really don't want to be buggering around with interfaces and I'd really rather avoid recording sound and audio separately and combining them as life is too short. I can use a usb lead to plug the amp directly into my laptop so may be able to plug it directly into my phone. Will have to try but will need to get a suitable cable first.
Of course, what I should be doing is spending the time practicing. I'm foolishly going to try leaning the Hey Joe solo which is madness as it's way above my skill / talent level!
https://youtube.com/shorts/wc-yI3A3rTE?feature=share
Posted : 25/04/2023 6:18 pm
First guitar lesson booked. Pretty much a novice. I can strum lots of chords and even play some easy tunes but need a kick to get me into some good practice habits. Wish me luck...
Posted : 30/04/2023 12:35 pm
Wish me luck…
You don't need luck, you just need to listen to your teacher and practice what they teach you. I think the main things are to enjoy it and not be too hard on yourself when things don't click as quickly as you want them too (I'm rubbish at this bit!)
Posted : 30/04/2023 12:56 pm
As Simon said (and you have to do what Simon Says) enjoy it. Set reasonable goals and if you can, find others to play with.
My playing really improved once I started regular meets with others in the area. I met up with a mate for a couple of hours yesterday, we work on songs rather than technique and this afternoon I'll be doing more of a muckabout jam casual fun thing. There may well be blues widdling. But we do usually start with a song to improvise over rather than a basic blues in B Minor.
Its all learning and all fun.
Posted : 01/05/2023 12:16 pm
chipps and simondbarnes reacted
I found the thing with learning guitar (or more recently bass) is not to expect too much of yourself! To play well takes hour upon hour of practice, and dare I say, disciplined practice at that! As an adult you haven't got all those years of bedroom and jamming with your mates under your belt. I tended to glaze over when we were discussing triads and chord voicings, keys and scales etc and just wanted to play songs riffs or solos, but that's just a route to (adult learner) frustration.
When I took up the bass I just wanted to learn songs and did OK with online tabs and so on, but until I took proper lessons I was just practising errors and crap technique into my playing. I now spend time warming up, practising this week's stuff then reward myself with a good thrash on something fun and familiar.
Posted : 01/05/2023 2:17 pm
eddiebaby reacted
My top tip is to leave the guitar out in a room you’re frequently in.
And also, keep a clip-on tuner on the headstock (chords sound so much worse if a guitar is out of tune - and tuning a guitar by ear is a slow/hard process if you’re a beginner).
I’m sort of a guitar beginner too, but crossing over from years on bass (which will always be my main instrument) - a bit like an experienced MTBer taking up BMX (but with the only physical risk being sore fingertips).
Posted : 02/05/2023 11:10 am
eddiebaby reacted
Yay, New Guitar Day!!!
Well it's second hand, but new to me. A Faith Neptune in high gloss finish.
Posted : 15/05/2023 3:04 pm
tall_martin reacted
Lovely!
Posted : 15/05/2023 3:26 pm
Well it’s second hand, but new to me. A Faith Neptune in high gloss finish.
I got a mahogany Neptune a few weeks ago. It needed no set-up, sounds gorgeous and is far and away the easiest guitar I've ever played, beating my mate's expensive Martin in the playability factor by a mile. On Saturday night, I was drunkenly* wondering to my wife about how good the top end Faiths are if the mid-range ones are this good.
* MTB in the sun all day, followed by a few beers on the beach. Home for food and share a bottle of wine with my wife, while lazily playing the guitar all night and catching up on the Giro. Not the perfect day but getting there. 😀
Posted : 15/05/2023 4:58 pm
Trying some fingerpicking this afternoon. I find it really tricky!
https://youtube.com/shorts/bJrrJ7Nvteg?
Posted : 15/05/2023 6:41 pm
Played our 18th gig to a packed out Red Barn in Woolacombe on Saturday.
It was a blast, great crowd, we played well and we helped raise 3 grand for the surf lifesaving club!
Top night out….
Posted : 15/05/2023 9:04 pm
All sorts of envy here.
Posted : 15/05/2023 9:25 pm
I want that carpet 🙂
Posted : 16/05/2023 8:18 pm
It doesn't take much to make me laugh...
[url= https://live.staticflickr.com/65535/52915991057_bfd097eabe_h.jp g" target="_blank">https://live.staticflickr.com/65535/52915991057_bfd097eabe_h.jp g"/> [/img][/url][url= https://flic.kr/p/2oC1hzp ]PgSvaBC[/url] by [url= https://www.flickr.com/photos/146501625@N06/ ]John Stanley[/url], on Flickr
Posted : 22/05/2023 1:38 pm
I'm imagining an Andy and Lou conversation there.
"That one".
Posted : 27/05/2023 8:19 am
I can't unsee that now.. 🙂
Feeling very proud of myself here. Was going to collect a Universal Audio Dream 65 "Deluxe Reverb in a box' pedal from Andertons tomorrow. Woke up at 3am and whilst waiting to fall asleep again I realised it wouldn't sound any better that the carefully crafted clean/breakup sounds I worked on with my my BOSS multi FX.
So I cancelled it.
I've never done that before but I'm down to a mini pedalboard of GT1000 Core with a compressor, a £19 Behringer graphic EQ pedal and a tiny "Marshall in a box" - a Dirty Little Secret- for my drive sounds. I don't need or want anything more.
Two presets on the Core plus the EQ and DLS give me everything I need with delay and rotary sounds handled by the Core - or whatever I need depending on the patch I set up.
Only really got tomorrow free as the Bank Holiday disrupts my usual time off but I'd rather spend it playing guitar with mates than going to Guildford to give Andertons more of my money.
Posted : 27/05/2023 9:48 am
Purge from the last few weeks
3 Strymon pedals
/13 Amp
Japan Jazzmaster
Money in the bank
What do I 'need' now?
Posted : 27/05/2023 11:03 am
Morgan AC20 amp.
Posted : 27/05/2023 2:12 pm
OK.....I'm sooooo slack....and sorry to the diligent folk of this parish that submitted stems back when vbrakes were new.
It's here.....STWv2 (or is it now v3?)
https://soundcloud.com/adamt-9/stw2-final-mix?si=4210234946ec4e1c88c8b866799ff6f6&utm_source=clipboard&utm_medium=text&utm_campaign=social_sharing
I'm open to doing another one at some point. Chord sequence suggestions welcome. Real bass players, drummers and keyboardists (and anything else) also very welcome.
Solos in this order/timing
Ads 56s
GuitarHero 1:22
forgotten username (Bryan) 1:48
Benman 2:20
Posted : 27/05/2023 2:13 pm
 beej
I'm forgotten username! Thanks for doing this, seems a while ago and hopefully I've improved since then.
Great hearing the other versions. I really struggled to figure out what to play.
Posted : 27/05/2023 6:32 pm
Nice one @beej Ads=AdamT, so it's nothing personal, I forgot my own username! 🤣
Posted : 27/05/2023 7:07 pm
Excellent, I like that, well done chaps 🙂
Posted : 27/05/2023 7:57 pm
Appreciate the efforts Adam. The syncing on my solo is out. Should sound like this. Was quite happy with so thought I'd post
https://soundcloud.com/barry-dodds/stw-guitarhero-track?si=9c4b199984084f03a4c314bc95aba490&utm_source=clipboard&utm_medium=text&utm_campaign=social_sharing
Posted : 28/05/2023 12:53 pm
Awesome noodling, folks!
Posted : 28/05/2023 1:06 pm
@guitarhero sorry about that. Tried a few but wasn't sure. Sounds great
Edit: you're still my hero!
Posted : 28/05/2023 10:31 pm
No worries @AdamT, the stem should have aligned with a 4 count prior to start. Apologies if I made it difficult.
Posted : 29/05/2023 1:59 pm
I think mine is slightly out of time too. Its that long ago, that I can't remember if I aligned to the 4 beats at the start of not...
Posted : 29/05/2023 5:16 pm
Once I can grab the laptop back from the missis I'll maybe have another go.
Posted : 29/05/2023 5:24 pm
I've been fancying swapping out the pickups in my main (only) guitar for a while. It's an Ibanez with some of their own brand active LoZ humbuckers. I don't not like them, but just fancy a change. I always liked the idea of coil splitting, as I don't have room for tons of different guitars and would like the flexibility, but split humbuckers almost always sound weak and crap. HOWEVER, I've been eyeing up some Fishman Fluence Classic pickups, which look very promising, which do have a true single coil voicing option.
atention grabbing image goes here
Has anyone used/fitted the Fluence style pickups before? Any thoughts or insights?
Posted : 31/05/2023 6:50 pm
Not sure if this has been posted but this was an enjoyable nearly two hour viewing
Posted : 12/06/2023 1:21 am
I watched that - thought it was pretty funny that he bought a Valvestate and one of those WEMs and ran them both as a rig that made it onto the first album, nowadays players probably wouldn't admit to liking either of those amps . His story about Johnny Roadhouse music is true, it was a proper madhouse back then and hasn't changed much since, its a lot more organised now.
Posted : 12/06/2023 12:53 pm
Page 41 / 54
