GPX file editing he...
[Closed] GPX file editing help
I'm wanting to edit a gpx file that has gone slightly off piste.
I want to keep the time data.
I've got tracklogs, and if I try and edit the track in that, it amends the time data according to naismiths rule (I've tried deleting the naismith rules and that just gives a ride time of 0:00)
Any ideas? Preferably a way that I can drop the gpx file onto a map underlay, and then drag the errant points to where the should be.
Ta Rich
Posted : 08/01/2013 3:14 pm
 Bez
Have you tried uploading to one of the online thingies like Bikeroutetoaster, Mapmyride, Ridewithgps etc? It'll be a bit trial and error, but some might preserve the time data.
Posted : 08/01/2013 3:21 pm
Everytrail is an online logging site with a map editor that lets you cut (and also move) points.
I suspect mapmyrun/mapmyride, runkeeper and some others let you do this too? (not sure)
Sometimes, I just open up the file in a text editor and cut out offending bits of XML (need to know what to look for though, and seeing the track on a map can help)
Posted : 08/01/2013 3:22 pm
Tried everyride and mapmyride so far with no joy.
Posted : 08/01/2013 3:55 pm
[url= http://sourceforge.net/projects/gpxeditor/ ]GPX Editor[/url] finally saved the day ๐Ÿ™‚
No map, but matched up with another.
Posted : 08/01/2013 4:50 pm
