Google Play Music /...
[Closed] Google Play Music / similar services and
Many years behind the times as usual I am having a go at this online/downloaded music malarkey.
Downloaded my first album from the Play store which now works fine in the Play app but its not visible to the Sony Walkman app, which seems to have its own built in shop thing. I also have amazon music installed. Please tell me that there is a way I can buy music from these and other legitimate sources and play them through one sodding player without hours of faffage? I can't even find the actual album I downloaded from Play as a file (yes I did see it download and can see it in the app).
Android phone btw
Posted : 14/08/2014 11:30 pm
Depending on how much you spend on music per month/year and whether or not you're normally in range of a WiFi network, you might be better off just subscribing to Google Music for £9.99/month.
I do, and it's the best tenner a month I spend. All the music I can ever listen to, streamed or downloaded to the phone, and if there's something Google doesn't have I can just add it myself.
Posted : 14/08/2014 11:54 pm
Wot he said above...
Posted : 15/08/2014 12:04 am
Just switched from Spotify to google, for the simple reason that you can play choons on multiple devices at the same time. Spotify pauses when someone else clicks play which is irritating.
Posted : 15/08/2014 12:40 am
If you've got a samsung phone you can currently get 90 days free access to google music.
I've been using google music and spotify, they're both pretty similar although some music is only available on one platform or the other. Both equally as good as each other though.
Posted : 15/08/2014 8:58 am
If you are looking for the tracks on the walkman then I assume you have installed the Google music manager on your computer and synchronised your library?
If so you should be able to get to it locally?
Posted : 15/08/2014 9:24 am
