Google calender syn...
[Closed] Google calender sync
I've installed this on my PC and got it all working great with Outlook.
My other half also has a profile on the same computer she doesnt need Google sync is there a way I can prevent it loading or starting when she opens her profile which doesnt effect my settings?
Posted : 11/08/2011 9:52 am
If she logs in, (right?)-clicks on the icon in Systray and picks Options, is there a 'load on startup' option there she can disable? Should be profile-specific if so, though I've not used it in about two years so can't be sure exactly.
Posted : 11/08/2011 10:09 am
Thanks for the advice.
I deleted it from the start up folder in my other halfs profile which deleted it from mine also.
I then put the short back into my start up folder and its not appeared in my other halfs, so problem solved.
Posted : 11/08/2011 10:31 am
It uses Startup? How very 20th Century of it.
Yeah - that'd do it, anyway. You've effectively moved the shortcut from 'Documents & Settings / All Users' to 'D&S / yourname.'
Posted : 11/08/2011 10:49 am
