I eventually got the thing to charge off the mains.
I did the update, I have been able to to take some stills but no video (it records the sound only).
I then re formatted the micro SD ( class 10 Sandisk)
Any Idea's ? before I send it back.
Is it a real Sandisk?
See [url= http://goprouser.freeforums.org/this-is-why-ur-black-freezes-t12096.html ]this thread[/url] and test the card. Also use the search on that forum, I'm sure there have been others with the same problem.
I hope so bought it from Currys, direct from a shop, as I was in a hurry.
Thanks for the link, I will have a read.
What are you opening the files with?
Window media player, what should I be using ?
Can't remember if that is compatible, download VLC.
sounds like you are missing the correct codec
