glass wall advice?
[Closed] glass wall advice?
I’m looking at knocking down the wall between our living room and lounge, adding a beam for support, and then having a glass wall with door. Pit falls? Building regs issues?
I don’t want anything on the glass, just clear and I want it all frameless and sleek. It looks like the only people supplying this are office partition fitters, and it’s very difficult getting a ball park price without a site visit which is tricky because I have not made the opening yet. I found https://www.glassatwork.co.uk/frameless-single-glazed-glass-office-partitioning-p-16.html which suggests about £2200 fitted but it's saying you have to have a film (some dots on the glass) for building regs. Anyone else done this on here?
Posted : 18/08/2014 11:25 am
if you do do it will you promise to post videos of drunks, small children and dogs walking into it in a comical (and not at all staged) manner?
Posted : 18/08/2014 11:31 am
Put the dots on (if they are needed for domestic building regs - you can check this with your local council planning dept).
Then simply remove them once you have the work passed.
But - do you even need to get building regs for interior changes???????
Posted : 18/08/2014 11:34 am
 IA
Will do for removing the wall I think? Building control not planning:
http://www.planningportal.gov.uk/permission/commonprojects/internalwalls/
Posted : 18/08/2014 11:36 am
I did this in our old house using 10mm toughened glass set into ally channels in wall and floor and a slot in the ceiling so all top fittings were in the void between first floor joists
Depending on your situation you may need to use fire rated glass ( if you have aloft conversion ) which then becomes mega money
check with local building control as too what regs they will req
cant comment on costs as mine was done on the cheap as I have good trade contacts - all in about 1500£ materials - installed myself
Posted : 18/08/2014 11:39 am
+1 MrNice
The dots are there for a reason.
Toughening or laminating to ensure safety.
That will be quite a weight of glass concentrated along a thin line so a "frame" may be still there but invisible.
UK Glass used to do some challenging domestic work.
Posted : 18/08/2014 11:42 am
Thank you OP and fongsaiyuk - I just realised something clever we could do In our house..
Posted : 18/08/2014 11:57 am
Check through Part B Means of Escape carefully before you go any further. That will tell you whether it needs to be fire rated, which will make a huge difference in cost and compliance with building regs.
Posted : 18/08/2014 12:27 pm
The only way to get a decent pay rise is to change companies. Next!
Posted : 18/08/2014 12:31 pm
I don't think manifestations on glass is a requirement in the regs for dwellings. Formerly in Part N of the regs (pre-April 2013), now in part K.
Posted : 18/08/2014 12:55 pm
[i]manifestations on glass[/i]
that sounds a bit spooky 🙂
Posted : 18/08/2014 12:58 pm
Manifestation requirement applies to non-domestic buildings only. But you've got to think about the likelihood of children running into it, visitors etc not being familiar with your house walking into it.
Also try Planet Partitions and IQ Glass for quotes.
Posted : 18/08/2014 5:52 pm
